#11 |
You're correct infinia, it's the full range B20 (B20FU20-51FW) that is prefered.
Its response starts dropping off around 12kHz though and that's why many have ended up adding a helper tweeter. R/ Jim |
#12 |
So this one without a whizzer may be better for LF bass and thus requires slightly different box?
With added tweeter crossed in at 3KHz or so requires a filter on the B20 becoming more or less a 2 way design for best integration.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 21st March 2010 at 08:45 PM. |
#13 |
I've been toying with the idea of building a box like this as a first project, and have some different dimensions in order to get them back into corners, but with the driver high enough to clear end tables.
With PE carrying these at $19 each, it sounds like a good starter project, anyway.First off, will they be okay 3-5 inches from the corners? Second, will these dimensions work? |
#14 |
>>> Second, will these dimensions work? Yes and yes! Looks good. Some are playing with porting ideas that may enhance bass response but that doesn't mean you can't build what you have there without getting great results. Which tweeter are you using the little dayton press fit? If you are i will get a pair too and play. |
#15 |
frugal-phile(tm)
The box aspect ratio is sufficiently far from a cube that it will have some half-wave TL characteristics (tuned to ~170 Hz if my calcs are correct)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#16 | ||
I actually like the "sound" of them, but there is very limited soundstage, if I have the term correct. They are also hard to get up high enough to listen to, yet look unobtrusive in the living room.I have a couple of problems though. I have pretty severe tinitus, which is so loud that I can hear it at highway speeds with the windows down. This is combined with a large dropout in my hearing from the high midrange and trebles (which I why I'm heading straight for a tweeter in the package). So, I like to listen on the loud side to get over my built-in noise floor. I don't have any gear for measuring, but I'd say I listen at a level where it would be quite hard to communicate with someone else in the room, 100-105 dB or more? I also have a ton of spare time (believe me it IS a problem), and just enough money to put a little aside for a pair of economy speakers (and an old component now and then). I loved Jeff's description of this driver in the cabinets he experimented with, and decided to give it a try. I was considering the Frugal Horn Mk3's but figured these would fit better in my corners and it wins in terms of frugality as well, especially as a first project. |
#17 |
Parts ordered!
Is the WIN ISD beta a decent source to calculate the port for this project? Kurt |
#18 |
Good call, optimized driver location ~15-1/8" down.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#19 | |
GM
#20 |
frugal-phile(tm)
Hard to put an 8" driver in a box 5" wide
![]() dave
| Testing box configurations with Pioneer B20 | davidallancole | Full Range | 5 | 1st January 2013 01:08 AM |
| Pioneer B20 comparison??? | mikje | Full Range | 8 | 27th August 2009 07:57 PM |
| Pioneer B20 in the uk | valleyman | Full Range | 16 | 1st August 2008 01:49 AM |
| pioneer b20 is on sale... | nebojsa | Full Range | 26 | 6th July 2008 01:00 PM |
| A Pioneer B20 Enclosure... | shloky | Full Range | 6 | 13th September 2007 12:06 PM |
