Mpl
Mpl
Old 1st July 2013, 05:41 PM   #351
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
They have enough brain to collect some money.....
Old 1st July 2013, 05:43 PM   #352
I even had a patent on that setup...
but i went much further...
google " Gekreuzte Schallwand "
Old 1st July 2013, 05:56 PM   #353
Gekreuzte Schallwand - Dokument DE102008016703A1
when you study this more carefully you will see that i even patented the " Phanton Source"
I should be rich by now. Many speakers produce phantom sources.
Old 28th July 2013, 06:24 AM   #354
This is an interesting site :
retro vintage modern hi-fi: Spherovox - Corner Folded Horn
Old 29th July 2013, 01:08 PM   #355
nigel pearson is offline nigel pearson  United Kingdom
Hi Jochim . I noticed in item 23 the test unit was high up and I suspect offset a little . Sorry I have not followed all the thread so I am asking you to repeat yourself . Could it begin to work so high up ( 80 Hz ) . I will be doing this with a pair of Eminence 12LTA soon and couldn't beleive I might be doing the right thing . I notice you don't extend the back too far ( later on ) . I was thinking about 10 cm ( 1220 x 606 panel ) .
Nigel
Old 31st July 2013, 07:37 PM   #356
expose 3D printed desktop speakers by simon ellison
Old 31st July 2013, 07:43 PM   #357
That is an Enviee in a 1.2m x 1.2m baffle. It is offset to linearize the frequency response.
In that baffle it goes to ca. 100Hz -3dB and i use an active M-Dipole sub.
Later i made the baffle only 60cm wide. In that case i use a double layer of acoustic foam in the back so that is more a cardioid.
I called that resistive baffle and it also works down to 100Hz and is only half as wide.
If you want to make a dipole woofer in a baffle with your Emminence i would put the woofer close to the floor. There was a Martin King design that way.
Old 31st July 2013, 07:45 PM   #358
Here you go....
http://www.quarter-wave.com/OBs/OB_Design.pdf
Old 31st July 2013, 08:21 PM   #359
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpl
Originally Posted by Joachim Gerhard View Post
Another cool link... thanks
RC
Old 27th August 2013, 06:47 PM   #360
Acoustical Society of America - 161st Lay Language Papers
MplHide this!Advertise here!
Copyright ©1999-2017 diyAudio
