Suitable enclosure (or none) for E-V 12TRXB - Page 2 - diyAudio
Old 12th March 2010, 01:07 AM   #11
Budgie is offline Budgie  United States
As long as photobucket lets me.
I will check out that vintage EV web site and see if I can get the bits of literature I have to them, also.
Old 12th March 2010, 03:31 AM   #12
GM is offline GM  United States
GM's Avatar
Cool! Thanks!
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th April 2010, 03:08 PM   #13
Hi guys! Thanks for help - meanwhile I have laid my hands on one more pair of these drivers - so now I can try out both cabinet suggestions. I took some 3/4" plywood (4' x 4' approx.) and mounted a pair of these drivers and tested how they sounded in an open baffle - not at all bad after decades! These deserve proper cabinets, definitely!
Old 23rd July 2013, 04:36 PM   #14
GM,
I have a pair of 12trxb's that, I am finally going to build an enclosure for. Could you look over this info and help me with a final design?
The baffle width I can use is = 29.75" Internal.
L= 60"
CSA= 457.81"^2 [suggested golden ratio?]
Vent = 78.54"^2 x 3"L [ 10" dia. x 3" L?] or [ what slot dimensions needed?] also can the baffle thickness [ 0.75"] be used in calculating port or slot?
Can the driver be placed up 37.25"?
Vent up 6.75"?
Thanks,
Cambe
12trxb question kvk Full Range 7 8th March 2008 08:21 PM
Bought a woofer, need help finding suitable enclosure Simpleton Subwoofers 12 11th May 2007 03:42 PM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 09:49 PM
Copyright 1999-2017 diyAudio
