Old 4th March 2010, 10:41 AM   #1
Brisso57's Avatar
Default Refurbing a Peak / Coral coaxial
My Question relates to Peak coaxial 10CX50 drivers,
aka Coral 10CX501.
I have two in good condition, and I want to replace the discrete components with top class modern replacements.
Is there anyone who has done this?
What are the component values?
What brands should I consider?
Doug
Old 4th March 2010, 03:44 PM   #2
frugal-phile(tm)
planet10's Avatar
Doug,
Pop the cover off and let us know what is there and what values their are, It would be best to physically separate the XO from the driver's magnetic field.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th March 2010, 08:46 PM   #3
Brisso57's Avatar
Thanks Dave.
I'm usually of the opinion that the less ham-fisted intervention the better, so I was hoping so-one may have trodden the path before me. Nothing I have found on the web gives the component values. If I get no answers before the weekend, I will carefully do as you suggest.
Doug
Old 7th March 2010, 01:23 AM   #4
Smile Peak 10CX501
Hi Doug, I've got a pair of these in a ported 95 liter enclosure.
Originally they were fitted with a 2 µF electro in series with a 15 Ohm wire wound resistor.
I have since pulled out the original tweeters and replaced them with a pair of Vifa OC25SC25-04. The highs are much better overall. I now use 4.7µF Mundorf M-Cap in series with a 18 ohm 2W metal film resistor.
Hope this helps.
rgrieg11
Old 7th March 2010, 11:25 AM   #5
Brisso57's Avatar
Hope this helps.
rgrieg11
Picture pls?
Doug
Peak (or Coral) 8CX-50 sunnycue Full Range 35 5th July 2011 06:53 PM
FS: Coral alnico 6 inchers and Coral H-12c alnico tweeters MichaelPublic Swap Meet 2 27th June 2008 11:24 PM
200V peak to peak @25MHz ketan Parts 1 8th June 2008 03:21 AM
Pre Outs and peak-to-peak ? CheekyMonkeyVZi Car Audio 7 12th December 2006 08:30 AM
refurbing orion 225hcca Clipped Car Audio 3 3rd August 2005 06:58 AM
Page generated in 0.07601 seconds (74.99% PHP - 25.01% MySQL) with 10 queries
