I have been experimenting with the Ikea sphere speaker.
To join the 2 bowls tohether I made a wodden ring that goes between them. All around that ring, I placed 8 small ports calculated with WinIsd. Now, if I listen to the speaker from above there are some bass (relatively to the small 3" full range I am using). BUT, if I listen to it with the driver facing me there are much less bass. I have never came across this kind of bass cancellation. And, as bass are supposed to be omnidirectional, the cancellation should happen from any listening position. Is that effect due to the multiple port, to the ports position (in a ring) or what? And how to calculate the port to have it "playing" in phase with the driver? I would appreciate your opinion to help me understand what's happening here. |
#2 |
Nobody ?
#3 |
are you sure it's not just because when you listen on-axis, you're hearing the full output of the driver, which may appear the mask the 'bass' you're hearing off axis?
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#4 |
I did that test with some pure tones around 100Hz...
It might be the room. I have to try this elsewhere and even outside... But, is there a reason to worry about a kind of cancellation because driver and port are out of phase? |
#5 |
Hello,
have you got a picture showing the port and how the speakers position is in the room ? Best |
#6 |
I will post pictures asap...
But, in general, is it possible to have some low frequency cancellation because the driver and the port are out of phase ? |
#7 |
Assumed that a speaker is aligned within the usual limits i cannot
imagine that. At fb driver and port are 90 degrees out of phase. The port contributes the main portion at fb. Since your speaker is small, there should not be any delay playing a role for low frequencies. Maybe you should estimate Qb for your enclosure, possible that there is more friction in the port than you want. A friend of mine has a speaker where the port is outside the box and can be made pointing into different directions. Bass response is not independent from where it points to, seems to be a matter of room excitation. According to the books only the displaced volume should matter for the radiation of the port. Thin ice here ... i am not quite shure whether it is in some cases important where the velocity vector of the port points to, depending on the speakers position. Interestingly the velocity vector of your "port-ring" configuration seems to be zero ... Kind Regards |
| Downwards Bass port in a Bookshelf | Dan_Steele | Multi-Way | 3 | 25th July 2007 04:04 PM |
| KEF driver phase and the H-B generated phase | dlr | Multi-Way | 11 | 24th April 2007 11:56 AM |
| dual driver vibration cancellation really does work! | paulspencer | Subwoofers | 15 | 15th October 2006 06:14 AM |
| Phase plug for cone driver in mid-bass horn design? | mefistofelez | Multi-Way | 2 | 18th October 2003 07:59 PM |
| Bass driver with concentric port. | Circlotron | Multi-Way | 18 | 10th September 2003 12:48 PM |
| Page generated in 0.09569 seconds (74.99% PHP - 25.01% MySQL) with 10 queries |
