Old 23rd February 2010, 02:09 AM   #1
mach1 is offline mach1  Australia
mach1's Avatar
Default Coral Flat 5 in PAWO ?
I'm seeking opinions as to whether it would be possible to get good sound out of Coral Flat 5s in a PAWO similar to that used with the FE127E.
Tom Zurowski PAWO Rear Loaded, Wide Baffle, Side Venting FR125S Horn
any advice gratefully received.
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman
Old 23rd February 2010, 02:19 AM   #2
frugal-phile(tm)
planet10's Avatar
It would be a flyer for sure... i tried a lot of driver in that both before i found that the 127 worked...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd February 2010, 03:43 AM   #3
mach1's Avatar
Thanks Dave,
I'll dust off the table saw ....
Old 23rd February 2010, 05:40 AM   #4
lazyfly is offline lazyfly  Australia
I love the wide and shallow cabinets. I love Coral too Okay, the one I've got
Good luck with the project.
Old 23rd February 2010, 04:37 PM   #5
chrisb is offline chrisb  Canada
dave
I should be noted that the Supra-baffles on the Planet10 bamboo PAWOs were originally intended to accommodate switching from the original CSS FR125 (which delivered far better performance in other designs).
Since we previously had found the FE127E to be a "go to" driver - i.e. works reasonably well in just about any box, and particularly so in certain ones, it seemed a logical choice. I think the best description of the difference between these 2 drivers in the PAWO enclosure is that while the Fostex doesn't impress with as much bass energy and impact, it certainly behaves more gracefully when driven near / at its limits, and has a presence in the mid-range that by comparison I find lacking in the FR125.
That said, if you're looking for a wide/shallow design, I'd suggest that you also consider the Mileva. I've built/lived with both designs, and find the Mileva easier in terms of build complexity and room placement.
If you do decide on the PAWO, I'd suggest mirror imaging the plans for additional flexibility of placement in regards to side wall boundaries or furniture.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Coral Flat 5 t/s ballsingtripp Full Range 17 15th November 2009 08:46 AM
Coral Flat 6 vs. FE167e ? nodiak Full Range 0 27th November 2006 10:09 PM
Coral Flat 10 albertli Full Range 16 3rd August 2006 03:07 PM
coral flat 8 fullrange then_dude Full Range 9 25th September 2005 11:33 PM
Coral Flat 6 question. steenoe Full Range 4 29th June 2005 02:58 PM
Page generated in 0.08850 seconds (72.23% PHP - 27.77% MySQL) with 10 queries
