Old 17th February 2010, 02:55 AM   #1
Send a message via AIM to weikertball Send a message via MSN to weikertball
Default Fostex FE206E front horn?
Has anyone built or modeled a front horn for an FE206E? I just came across the thread for the front horn with the 6"er and doing one for the 8" really piqued my interest. 100-150 hz is what I planned on as the cutoff and I'll build some bass cabs to pickup below that. Thanks guys.
Old 17th February 2010, 04:14 AM   #2
zobsky is offline zobsky  India
zobsky's Avatar
which thread?
"Any fool can know. The point is to understand" - Albert Einstein
Old 17th February 2010, 04:29 AM   #3
bqc is offline bqc
I did, see thread below, starting on post #19. The mid range (150-600) gain was
about +10 to +15db. After I had the 206E in that front horn for awhile and I pulled
it out and put in a pair of OB similar to the Quasar, and I started to hear treble
details that I was not hearing before.
front horn designs - post your results / pics
Old 17th February 2010, 01:02 PM   #4
Formidable Fostex Front Horn
There's what I was talking about.
Old 17th February 2010, 03:51 PM   #5
chrisb is offline chrisb  Canada
I think Burt D has a pretty well established (albeit less dramatic) front horn that's known to work with FE206E, among others.
a few hours reviewing his current site might be of some interest
BD-Design, only the best!
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 17th February 2010, 08:15 PM   #6
BQC, what was the throat dimension on that horn you were using with the 206? I was unable to tell from the photo. (cool horn by the way)
From the Dinsdale article:
"...for higher frequencies, where wavelengths are of the same order as the physical dimensions of the loudspeaker diaphragm, the throat area should be made the same as that of the loudspeaker,...."
Small throat=greater efficiency but more high freq. attenuation.
Large throat=lower efficiency but less high freq. attenuation.
206 is pretty darn efficient as is, I would lean toward making the throat the same size as the driver as any fleawatt amp should drive those to insane levels in a front horn. If you haven't already, I would recommend the J. Dinsdale article and Edgar's midrange horn article for dimensions and building tips. Is there a particular reason you chose 100hz to 150hz as your cut off? Do you already have a pair of 206e's?
Derek
Old 18th February 2010, 01:54 AM   #7
I choose those frequencies because I figured if I go any lower, i would lose some efficiency in the mid-treble frequencies and I've already got plans for the lowend. I'm trying to fit as big as mouth as possible. I just think horns with big mouths look awesome and plus I want it to be as efficient as possible. I liked the design I saw in that thread, it was simple, looked nice and according to the OP, it sounded good.
The BD-Design doesn't help me out much. I couldn't find much info on plans
Old 18th February 2010, 06:21 PM   #8
bump.
Old 18th February 2010, 07:20 PM   #9
bqc is offline bqc
Derek
The mold was made with the intend to have throat size about
5" X 5". But I eventually chopped off the length a bit at the
throat to increase the throat size to about 7" X 7" (the size of
the 206E) . Even with this larger throat , a lot of high frequencies were attenuated, so much that I never knew that the
206E has a peak in the 2-3K region until pull it out of the horn
and put it in an OB and that is when I started to hear treble details that I did not hear before. That is why I think
206E may not be best in a front horn, it does not have enough
peak at the high freq like Lowthers to balance the 10-15 db boost in the lower mid range. It sounded great though, very dynamic and you can place them in corner without imaging issues
Old 18th February 2010, 10:57 PM   #10
Make the throat a couple of inches larger than the driver and you should realize more high frequencies. Still have to deal with that famous 206 peak though.
I have a pair of 206's and have a love/hate relationship with them.
Fostex FE206E BL horn speakers sarrisk Full Range 7 31st August 2008 03:04 PM
Backloaded horn with Fostex FE206E Arie Full Range 1 9th February 2008 01:28 PM
FS: Fostex FE206E (Decware modified) backloaded horn with Karlson Slot $299 bbaker6212 Swap Meet 4 24th September 2007 04:34 PM
Back loaded big spiral horn with Fostex FE206E thomaseliot Full Range 50 31st October 2006 06:12 AM
FE206E psuedo front horn? bbaker6212 Full Range 2 20th May 2006 10:17 AM
Page generated in 0.11448 seconds (78.04% PHP - 21.96% MySQL) with 10 queries
