After seeing HH article for the Alpair10 + 5, im searching for best application for them
I always like onken, and i found this onken calculator from mh-audio.nl - Downloads I calculated based on publish parameters on markaudio.com, and i come up with this result i need 97L box volume!!! i wonder if this calculator is right |
#2 |
if i calculated the box internal dimension would be 250mm x 400mm x 970mm.
Which still ok for floorstanding but with 8 ports, let say 4 each side, with height of 30mm and width of 18mm (3/4" materials). cheers henry |
#3 |
I tried to do simple drawing
#4 |
One or more of the specs you used is wrong based on the average measured specs posted awhile back. It's Vas is way too low for Onken loading, only for the Onken 'look' as a ~aperiodically loaded alignment, i.e. DD's Fonken concept. A 6 ohm series resistance is going to dramatically increase the cab's net Vb/lower Fb over one designed for a SS or similar vanishingly low output impedance source though.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 |
OK, looking at the published specs, you inputted the wrong Re and Sd plus markaudio's Sd spec is wrong unless it's some arcane metric unit not normally used as it should be an area unit of measure such as cm^2, etc..
Regardless, input Re = 5.4 and assuming the published Sd should be 89.9 cm^2, then input Sd = 8.99e-03 for a bit more realistic design, yet not so much considering its TL length vents. GM
#6 |
frugal-phile(tm)
Henry,
Here is the planet10-hifi primeSize milliOnken (looks like an Onken but has nothing to do with Onken calculators), http://homepage.mac.com/tlinespeaker...map-181209.pdf dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Dave,
For your drawing note 1: 14 L = ~854.33"^3 = ~0.4944 ft^3. Got a measured response or at least a sim? The reason I ask is that the Onken calculator might make an excellent Fonken calculator to find cab net Vb, Fb, vent areas. For instance, ignoring any series resistance, this driver calculates a n = 6.34 ~12.86 L/44.6Hz Fb, so curious if the minor reduction audibly affects it. Or, if it does and the calculator is off by roughly the same percentage on other Fonken designs, then we can change the 'n' factor as required to average them out enough to make a dedicated DIY designer same as the BIB. GM
#8 |
frugal-phile(tm)
Interesting idea. When i do these i look for a specific curve shape and then estimate response by interpolating with the sealed response at the same volume.
Going back to the drawing, actual volume is 826 in^3 less whatever the driver takes up. 14 litre is the gross volume before braces & drivers, target was 13 litre net (just under 800 in^3) Sim is 13 litre 50 hz tuning. dave
#9 |
Thanks!
YGM, GM
#10 |
Hi GM, thanks for correcting me.
Dave, thanks for sharing the plan, will it work for alpair10 bass? which have slightly different Q and mms. cheers henry |
| My 'Moon-Onken' | Bigun | Full Range | 142 | 23rd May 2012 02:09 AM |
| Alpair-10 with Alpair 5, German combo | markaudio | Full Range | 17 | 7th November 2010 11:58 PM |
| Alpair 10 Bass + Alpair 5 - Woodwill Japan | markaudio | Markaudio | 16 | 26th January 2010 11:48 AM |
| Onken, anyone? | cyclotronguy | Multi-Way | 155 | 28th May 2009 05:22 AM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
| Page generated in 0.10474 seconds (86.63% PHP - 13.37% MySQL) with 11 queries |
