Hello,
I plan the construction of a small BR box for my desk. As a driver I have the Markaudio CHR-70 or the TangBand 4W-1320 selection. The case has about 6 liters net. Which driver is better suited? Michael |
#2 |
frugal-phile(tm)
I know that the CHR-70 works well in 6 litres (i'd leave sealed or maybe aperiodic)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
hello.
in the german magazine klang+ton 4/2008 there is a box with the tb w4-1320,......cheap trick 237...........a 5 liter bassreflex box. and on Lautsprecher Selbstbau by blue planet acoustic there is a kit too............ greetings |
#4 |
Depending on what you consider a "small speaker", this is worth a look: http://flogatt.kilu.de/Hifi-Forum/Sa...%20FloGatt.pdf (uses the W5-1611)
/U. |
#5 |
Buy 2 of each the give the worse pair away as a gift.
Norman |
#6 |
ZillaAudio.com, Outdoor Speakers | Rock Speakers | Garden Speakers | Patio Speakers | In-Wall Speakers | Ceiling Speakers and more!
I have not heard the MA but expect it will be great based on comments. The Tangband is also a great speaker. Use a super tweeter to get the most from the top octaves. I live happily with a pair as my 'home theater' system. Neither is a bad choice. I'd purchase the MA's if i didn't already enjoy the TB's. Godzilla |
#7 |
If you want to run it full range, I'd recommend the W4-1320. It has better top end of the two in my experience.
#8 |
And, in fact, the better bottom too in 6 litres vented box tuned to about 75 Hz. The CHR-70 will need about 17 litres to play optimal bass.
I have first hand experience with W3-1364 which also is a bamboo cone. Excellent performer. /Erling Last edited by skorpion; 12th February 2010 at 05:42 PM. |
#9 | |
THe choice between my CHR-70 and TB's is naturally for each individual. So it's not for me to comment. However, some comments are technically incorrect: Erling: - Vented at 6 litres? I'm not sure if you're referring to the TB or CHR. For the new CHR-70, depending on who's software is used to make the calculation, expect a 6 litre BR box to deliver a port resonance of 60Hz, cut-off at 57Hz. Port sizes would be around: 25.4-mm (1") Dia - length of 51-mm while a 40-mm Dia. would be 140-mm long. 17 litres? This is not an "optimal" BR box size. It's far too big. Power handling would also be limited. For the new CHR-70, expect optimal bass in BR at around 11 litres. For the new CHR-70 specs - please see: http://www.markaudio.com/chr70 Cheers Mark Last edited by markaudio; 12th February 2010 at 10:36 PM. Reason: Typo mending |
#10 |
I agree with Mark that the new revised CHR-70 is optimal in a 'around 11 litres' BR box. My WinISD calculation shows 11.5 litres and it will also better tolerate to shrink volume to 6 litres. I used specs for the original unit for my calculation above. I am sorry I had not observed the revision.
/Erling |
| CHR-70, CHP-70, Alpair 7 Desktops - Japan | markaudio | Full Range | 4 | 1st February 2010 01:42 AM |
| Tall Curved Cabinet for TB W4-1320 | morfic | Full Range | 2 | 21st October 2009 02:38 AM |
| Any TB W4-1320 experience | tuscanasun | Full Range | 1 | 9th December 2006 09:55 PM |
| TB W4-1320 twin driver TL for 2A3 | Bing Yang | Full Range | 10 | 4th July 2006 12:03 PM |
| Designing a notch filter for the TB W4-1320 Bamboo driver... | fjhuerta | Full Range | 8 | 26th November 2005 03:19 AM |
| Page generated in 0.10902 seconds (74.40% PHP - 25.60% MySQL) with 11 queries |
