Hi all!
I was wondering if someone could advise me on some cheap fullrange speakers to build some BIB´s? thanks in advance |
#2 |
frugal-phile(tm)
The BOFU BIB would certainly qualify.
Build it out of OSB like Variac did and it should come in under $100 (plus whatever extra it may cost to get the drivers to where you are). Or GY Chang's with the 4" Pioneer, cost half that. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I thank you for your kind reply!It sure looks great!
It is a pain to find whatever pioneer driver here in Portugal though... I´m about to read some reviews on it´s sound quality,but nonetheless,sure looks tasty!
#4 |
The Dayton RS100-4 iBIB is quite cheap, and easy to build from fencing wood, cheap and no rips needed. Sounds great.
#5 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 |
why not try a european driver? the monacor sph-60x (or 68x) is cheap and easy to find. i built a bib for a friend and 2 years later he still loves it. impressive bass from a 5" inch driver.
i remember some talk of some very cheap tesla drivers a while back -- with a little research you may find a good candidate. |
#7 |
Being inside the EU, you can buy from anywhere inside the union, can't you?
Here's just one example, - there are several more... http://www.spectrumaudio.de/breit/pi...0FU2051FW.html
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! Last edited by AuroraB; 14th February 2010 at 10:23 AM. |
#8 |
It's my understanding that this is a functional equivalent to the RS 40-1354 that T.C. used in his original BIB except better and with a more extended HF. If so, then using this driver in his BIB seems a great 'el cheapo' ~full range speaker choice.
GM
#9 |
it is done everybody!
Just had me some monacor sph-60x bought online! It is very unusual to find this sort of material for audio diy.Not much happening around here...unfortunately! I´ve been absolutely delighted reading some posts in this forum and I´m starting to learn something from all of you! I´ve tried about six months ago to build Cyburg´s viech.But it is really hard to find any shop here where I can have the wood cut.I know it´s stupid,but it´s true!And so,I´ll have to try something easier (bib).The Beyma´s really are lovely sounding,even without any box... Yep,I´m already addicted to this diy audio thing.just purchased an lm1875 gainclone chip amp,but a cheap one from china! |
#10 |
I should have said it before (I believe I have in another thread) but I had much better luck with this driver and some tripath amps. Compared to a lm3875 gainclone the tripath amps I tried (Charlize, Amp32 and one from Arjen here on the forums) sounded much more full with more bass. I would not hesitate to try the Amp6 from 41hz and imagine this would be a great match and a really easy build.
Also, before cutting any wood what are room dimensions/placement limitations? Do you have corners, will they be up against walls, etc? With no corners, not wall loaded or high ceilings I would recommend a downward firing version. |
| Sonic Impact amp + iPod + BIB = Cheap Fun! | Godzilla | Full Range | 26 | 4th February 2008 09:46 PM |
| AJ-Horn & BiB - ar some BiB "parabolic"? | freddi | Full Range | 3 | 6th April 2007 03:09 PM |
| Scosche SPL meter: Cheap find with potential, or cheap junk? | theAnonymous1 | Everything Else | 5 | 11th October 2006 03:40 AM |
| BIB with cheap fr drivers, help needed | fcj | Full Range | 6 | 18th August 2006 09:38 AM |
| Page generated in 0.26220 seconds (34.95% PHP - 65.05% MySQL) with 11 queries |
