Old 8th February 2010, 01:15 AM   #1
Send a message via AIM to scottder
Default DIY Full-range Bookshelf for a Beginner
I am looking for a first DIY speaker project, and it seem something using a full-range speaker would be a good place to start. I'm looking for recommendations on a relatively simple cabinet design for someone with access to proper tools, but not much in the way of woodworking skills to ramp up with. Something that is well-known and documented online would be great as well in case I have any questions or issues.
Thanks in advance.
Scott
New to DIY
Old 8th February 2010, 02:30 AM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
I'd give these a try:
Meet the Fonkens
Very well documented.
Jim J.
Old 8th February 2010, 05:18 AM   #3
frugal-phile(tm)
planet10's Avatar
I'll point out that the number of designs in that family is expanding faster than my ability to keep up the webpage. More here: milliSize me...
And this at least mentions them all: http://www.diyaudio.com/forums/plane...ose-names.html
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th February 2010, 09:14 AM   #4
gaust is offline gaust  United Kingdom
This Zaph audio design using a pair of HiVi B3S seems very simple and an excellent starting point
Zaph|Audio
Old 8th February 2010, 01:03 PM   #5
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Speaking from experience, the Fonkens are great; however, they aren't necessarily simple as far as building the cabinets. They aren't horribly difficult, but since you mentioned "relatively simple" this site has some good projects.
Do It Yourself Speaker Building, Outdoor Speakers | Rock Speakers | Garden Speakers | Patio Speakers | In-Wall Speakers | Ceiling Speakers and more!
You can always download WinISD, buy a full range driver, and design your own cabinet, too. I'm by no means a speaker designer, but I put a Tang Band 3 inch driver in a box I developed with Win ISD and am VERY pleased with it. It's on my desk at work and sounds great. I have another Tang Band driver I've tried in a couple different enclosures, just to experiment. Mind you, there are no filters for these, just a driver and a cabinet.
Mike
Marantz PM8003 amp, HRT Music Streamer II DAC, Squeezebox Touch, DIY Krystals
Old 8th February 2010, 01:59 PM   #6
Thanks all for the pointers. There is a lot to dig into here.
mikje: Those look close to my 'speed' at the moment. Much appreciated!
Scott
New to DIY
Old 8th February 2010, 03:39 PM   #7
SY's Avatar
Check out the Arpeggio- very simple, well-engineered, and documented. It's in the Articles section of this site.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 8th February 2010, 04:56 PM   #8
Nanook is offline Nanook  Canada
Nanook's Avatar
Default puttin the cart before the horse....
For clarity's sake, I am a single driver "believer"
My typical peeve shall be restated here:
  • How big is your room?
  • What type of music do you listen to?
  • What amplifier(s) do you use?
When you answer these questions, you may end up with a speaker that is easy to build and one that may keep you happy for a long time. Single driver loudspeakers are very good, lots of pluses, but most notably the lack of a crossover and all the nasties that that can happen if you don't get a cross-over right. Cross-overs are hard to design correctly, even with good software.
Simplest enclosure is no enclosure (open baffle). Then well constructed, small Sealed 6 sided boxes (small so no internal bracing required), followed by small Bass Reflex. After that things like Transmission lines, etc. A 5 sided box (the Metronomes--see planet 10's site) can give some very good results as well. It all depends on the answers to the first three questions, and where you might want to end up.
Once you decide what you want in terms of size, etc then start looking at appropriate drivers and their manufacturer's recommended enclosures or well documented projects. Planet 10 is a great resource, regardless what drivers/enclosures you end up building.
stew -"A sane man in an insane world appears insane."
Old 9th February 2010, 04:11 PM   #9
1) Room is about 10x12' give or take.
2) A wide variety, big orchestral classical works to metal
3) I was of the mind to eventually build a T-AMP (AMP6-BASIC), so I imagine they would have to be relatively efficient speakers as well.
Scott
New to DIY
Old 9th February 2010, 05:28 PM   #10
Send a message via ICQ to Crossblade Send a message via AIM to Crossblade Send a message via MSN to Crossblade Send a message via Yahoo to Crossblade
Is there a popular bookshelf for FE207e?
Delsol- inexpensive full range bookshelf. pekar Full Range 151 4th March 2012 05:03 PM
simple, full range, bookshelf dsavitsk Full Range 8 15th February 2007 07:18 AM
Building a full range bookshelf enclosure aussiebuddha Full Range 6 10th August 2006 04:31 AM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 07:38 PM
Page generated in 0.12049 seconds (81.44% PHP - 18.56% MySQL) with 11 queries
