HIVI Trinity 6 -3 way
Old 8th February 2010, 12:13 AM   #1
shporsche is offline shporsche  Australia
Default HIVI Trinity 6 -3 way
Hey guys,
I have recently scored a pair HIVI Trinity 6 3-way Ribbon Coaxial speakers.
I'm having issue's trying to find a box design for them.
I have the specs from HiVi, however from previous use of HiVi there specs arent so accurate, and I dont have the equipment to test.
Have any of you seen a box designed for them?
HiVi now has a box design, however I couldnt find its specs.
I did find a crossover design for the speaker, but no boxes.
Old 8th February 2010, 12:45 AM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
MMhh..fearful ! Air movement is very limited by the steel chassis . The suggested crossover schematic takes in account each sub-driver's parameter ,trying to flatten the impedance rise of each way . Try to lower woofer's Qms
with a lot of <sound absorber>,even light felt around the basket.
Box won't be too big , I imagine . An Ikea bowl (two sandwiched) should work.
Cheers
Old 23rd August 2010, 11:37 PM   #3
Shaun is offline Shaun  South Africa
Shaun's Avatar
Interesting project! Any progress?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 26th February 2011, 03:33 AM   #4
jazbo8 is offline jazbo8
jazbo8's Avatar
Cheers
That was my initial take as well - why is the back closed by steel frame? I guess TL design is out of the question... Cheap enough to try something with it though...
Swan's cabinet - 215*295*385
Another Chinese cabinet - 360*240*400
Jaz
Old 26th February 2011, 06:46 AM   #5
It has been awhile, I put them into some box's same dimensions as swans built pair.
Haven't put a finish on them yet, I will post pics when they are done.
I'm quite happy with there sound considering what there are. The mid and bottom end are lacking slightly, however I think that has something to do with my crossovers.
Otherwise they are good.
Old 7th March 2011, 11:02 AM   #6
jazbo8's Avatar
If you want to get more bass, a larger cabinet will be needed, some people have tried the BIB with good results, it is an easy cabinet to build, more info could be found here.
Jaz
HIVI Trinity 6 -3 wayHide this!Advertise here!
HiVi D6.8 &amp; HiVi Q1R adavid555 Multi-Way 5 27th November 2008 02:14 PM
Trinity Tube Heads AriesMotor Vendor's Bazaar 0 14th November 2008 04:11 AM
Hi-vi trinity 6 in a horn enclosure? sqlkev Full Range 11 22nd September 2007 06:31 PM
HiVi Trinity 6 Arc Multi-Way 0 8th March 2007 03:27 PM
"Trinity Towers" pages added to web site Andy G Multi-Way 2 30th May 2002 12:35 AM
