Old 5th February 2010, 09:12 PM   #1
Default EnABL application for pro horn driver.
Friends,
I would like to order the EnABL kit and apply it to a Funktion-One horn speaker model Resolution 1.5 (see site and navigate to the "products" section to see the RES 1.5 speaker).
FUNKTION-ONE : OFFICIAL WEBSITE
my home system:
Picasa Web Albums - Herman
Basically, it's a 112db, 5" horn loaded driver incorporating an unusual phase plug that covers 600 to 15Khz.
1. I'd like to order the EnABL kit.
2. I will apply the kit and post my findings and pictures.
Thanks,
Herman
Old 5th February 2010, 09:22 PM   #2
frugal-phile(tm)
planet10's Avatar
Hi Herman,
Good to talk to you on the phone.
Ed's EnABL kit here
From the Funkion 1 website i'd say that the "thing" in the middle is more a part of the horn, than it is a phase plug. I built something similar, but much cruder, in the early 80s.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th February 2010, 09:26 PM   #3
frugal-phile(tm)
planet10's Avatar
PS: is that a MacBook Pro or an old PowerBook (kie mine)?
dave
Old 5th February 2010, 09:30 PM   #4
dave
That's just a Dell Latitude D620. A weird creature that needs all wifi to be disabled to play audio, otherwise it starts to stutter.
Also, I sent an e-mail to Ed, with my order request. Thanks for your help.
Herman
Old 5th February 2010, 09:47 PM   #5
frugal-phile(tm)
planet10's Avatar
With an Apple Logo on the lid? Oops, zooming in i see it is just a circle.
dave
Old 5th February 2010, 09:52 PM   #6
BudP is offline BudP  United States
BudP's Avatar
Some initial comments from a position of current, specific, ignorance.
I would treat the woofers first. Then I would treat the mid / woofer compression cone driver. Then I would listen for a good bit of time. Then I might treat the compression driver of the horn, but detailed high rez pics b4 you do that PLEASE!!!!!! Last I would treat just the outside edge of the horn flare. Then I would slowly work my way into the horn flare body and that of the wave guide plug.
You MUST be slow and attentive to horns. They can easily get so forceful and hard edged that you cannot listen to them. It is quite possible that the horn flare and wave guide plug will need no more than a parting edge treatment. It is also possible, though less likely that the CD will not need any treatment. It is certain that it will not need very much.
You really really really need a reference driver that teaches you about EnABL and how it portrays music before you tackle something as complex as this system. If you have a couple of hundred dollars to spare you could not do better than a pair of Planet 10 Fostex 127 eN drivers in small cardboard boxes. At no point in your life will you feel you have wasted that money! If you are intent on biting off this much, I would really like to feel confident you can survive and a clear target, which the 127's will provide, will help immensely.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Gamma Horn loaded Ribbon VLD-13 - Application Advice Needed icefox Multi-Way 30 9th June 2010 09:22 PM
horn speaker for car application mhtplsh Subwoofers 22 10th May 2010 05:57 AM
can auto, subs be used in a pro application? mastadon Subwoofers 20 12th March 2010 09:15 PM
Modeling a driver in an electronics CAD application Thinkcat Multi-Way 7 15th June 2008 02:33 PM
Back Loaded Horn with Pro Coax Driver djdan Multi-Way 10 15th October 2004 01:45 PM
Page generated in 0.09560 seconds (74.34% PHP - 25.66% MySQL) with 10 queries
