#51 | |
thanks, Colin with my propensity for math any more complicated than the square root of 1, this could be more efficacious than a pill or couple of shots of bourbon ![]() certainly that was the case with the recent Toole text - I was lucky to keep my eyes open for more than 1/2 hr per session.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#52 |
I spent years trying to figure out how to DIY speakers. Your article explained a lot very clearly. I just wish you had written this a few years ago, it would have saved me a lot of mistakes along the way. I had most of it down, but it was fuzzy, now it's not. One thing I had not figured out was how much delay a closed box roll off caused. You had that too.
I have some FE166E's in "storage". I'll make some of these. PS: Is the felt a "wool felt", and how thick is it? Thanks Jim |
#53 |
Hello Jim,
it's about 1mm thick and according to the label from the John Lewis department store: "70% viscose 30% wool Do not wash, sponge or dry clean"
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#54 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#55 |
A very good article Mr. Jones! Everything as very well explained as in your book on valve amplifiers.
I have a pair of Fostex Fe208 Sigma's and will make a pair of loudspeakers according to the same procedure as you described. Originally I used these in Jericho horns. Besides that, I'm also working on an amplifier of Mr. Pass' design. (I'm stuck now at the chassis and the heat sinks) As mentioned in on of the earlier comments on the article, on the ESP-site adjusting the output impedance of an amplifier is explained. If I understand well, an Aleph type amplifier is easily adjusted to a certain output impedance by changing the feedback loop? HJ |
| Arpeggio Loudspeaker | Morgan Jones | diyAudio.com Articles | 18 | 3rd February 2011 07:48 PM |
| So how tattered is your Morgan Jones? | Richard Ellis | Tubes / Valves | 8 | 5th January 2008 02:30 AM |
| Morgan Jones BALANCED? | vvs_75 | Tubes / Valves | 3 | 3rd April 2007 02:26 PM |
| MY Morgan Jones headamp. | digi01 | Tubes / Valves | 9 | 25th April 2003 01:19 AM |
| Page generated in 0.09245 seconds (77.74% PHP - 22.26% MySQL) with 11 queries |
