Questions about Metronome ML..
1. Is there any complete drawings to the Audio Nirvana 10" speaker? 2. What is the sensitivity 1W/1m.., high or low? 3. Where can I buy Audio Nirvana speakers in Europe? 4. How low in hz can I expect this config will go, -3 dB? humlan. |
#2 |
frugal-phile(tm)
1/ not that i know of
2/ whatever the spec is (if you can believe that). Is this the stamped basket one? (the cast may not be suited to a Met) The former is 95 dB by my measure. 3/ An is David Dick's house brand. You probably need to buy from US. 4/ Scott, do you still have the sim? dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Ok..., is there any other 10" element that will perform well, an bas/midrange maybe, and a tweeter?
Have anyone thought about a slavebass in the bottom, instead of the pipe? Do You think it will work? humlan. |
#4 |
Have also thought about the new "Phillips AD9710" HIFI KIT - Obi F87 and Monacor DT-28N tweeter...
humlan. |
#5 |
frugal-phile(tm)
That is an interesting driver. Conelooks a lot like the Visaton B200. Based on looks alone i'd pick that over the AN
dave
#6 | |
Do you think I can use same cabinet size, as for the Fostex 207E? This: http://i61.photobucket.com/albums/h6...anet10/2-1.jpg humlan. |
#7 |
Last I checked, Wolfgang at www.spectrumaudio.de had the AN line.
I think the AN10 Met. was a victim of my last HDD crash, or I could have it on one of my (many) spare old drives. I'll see if I can dig it out. No great surprises though; from memory, 38Hz Fp; nominal flat alignment. With a bit of fiddling with the cabinet position, you could probably get away without a BSC circuit but for the AN driver's inherently rising response, so you'd either need to listen ~10 degrees off-axis a la Jordan et al, or a shelving filter from about 800Hz if you're on-axis. Last edited by Scottmoose; 2nd February 2010 at 09:54 PM. |
#8 | |
Looks like a B200 with a bigger motor bolted to it / more electrical damping if the Qt figure is to be believed.
#9 |
frugal-phile(tm)
That one is interesting enuff to get Scott to do a sim... he has to do his lessons 1st thou (teacher, not student)
dave
#10 |
Tnx Scott!
Perfect, now I now where to buy.. I will be most thankful if you can help me with a complete drawing/size of the cabinet, that match the 10" AN. Hopefully I donīt need to take up a hole in the ceiling because of the hieght... humlan. |
| Metronome style design for multiple drivers, a number of design questions | mountainhick | Multi-Way | 5 | 28th January 2010 03:31 AM |
| Folded ML TQWTL Fostex FE167E Frequency Respose Questions... | ljfont | Full Range | 12 | 9th June 2009 05:57 AM |
| Metronome with FE167e construction questions | kyndig2 | Full Range | 4 | 30th January 2008 09:06 PM |
| Basic ML TQWT Questions | Shae | Full Range | 1 | 8th October 2007 08:14 AM |
| Page generated in 0.16038 seconds (65.94% PHP - 34.06% MySQL) with 10 queries |
