Old 2nd February 2010, 11:58 AM   #1
AdamZuf is offline AdamZuf  United Kingdom
Send a message via ICQ to AdamZuf
Default Transmission line: cheap, small as possible ~50-350Hz ?
I have a pair of wondrful Genelec 5" monitors I would like to use, but need a bottom end. Although I can just add a sub, I'm more intrigued on how it will sound if I will prevent the Genelecs from moving anything below ~250-350 Hz, and assign them just to the vocal range. I can do a reflex box, but I'm more intrigued by a transmission line.
I think that the sound of bigger drivers in the low mid is nice, so maybe 7-10" driver.
The loudspeakers will live in a small room, so the cabinet needs to be tall and narrow, front port, to accommodate a cheap driver. I don't really care about distortion in the unused upper frequencies so I guess it makes it easier.
Any suggestions on designs and drivers?
Does a bigger driver makes a smaller transmission line?
Adam
Old 2nd February 2010, 02:45 PM   #2
Scottmoose's Avatar
No, generally a bigger one, although naturally, this depends on the driver.
When you say you are intrigued by a TL, in what sense, viz., what are you hoping to achieve? The term has become so generic that, quite literally, what one person describes as a transmission line might be the exact opposite of what another person would describe as a transmission line (or some point in between). So before any sensible recommendations can be made, we need to know what you mean by it.
Old 2nd February 2010, 09:27 PM   #3
netbug is offline netbug  United States
I've seen tapped horns used in pro systems (ie. danley Sound Labs). I think that may be a better direction to go.
You may want to consider a simple H-Frame. I just finsihed a pair and I'm very impressed so far. A 15inch driver in a little 17.5"x17.5"x16" box.
MJK’s Jordan JX92S OB with a Goldwood GW-1858 Woofer in an H Frame
Suggerstions for subs doing 50-350Hz. swak Subwoofers 10 16th August 2007 02:42 AM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 04:18 PM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
What to do with small transmission line cabinets VvvvvV Multi-Way 5 3rd August 2004 10:14 PM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
Page generated in 0.06827 seconds (71.38% PHP - 28.62% MySQL) with 10 queries
