Old 2nd February 2010, 12:32 AM   #1
kirkl is offline kirkl  United States
Default indoor/outdoor and Dayton ND90-8
newbie here-bought the Pyle 40 watt amp. Just need a simple setup to use where speaker will be set up under a protected eve by the deck outside, removed and brought inside unless using it.
The full range Dayton has aluminum cone, and others I've seen have some composite cone. Is this a consideration for limited outdoor use or not to worry? Also, how is the best way to determine if sealed box or ported (screened to keep bugs out), and internal volume for each option. Or, how to determine inside volume enclosure requirement for sealed vs. ported.
Have no problem making box and putting in baffles/ports if necessary, I make furniture. Would like to spend $50 each on pair of decent full-range drivers. Have enough box material laying around. Any recommendations and comments please. (I know the Pyle is bare bones...)
Thank you.
Old 2nd February 2010, 12:59 AM   #2
You could make a box yes, but I doubt it would sound good. Making speakers is an art. I would not try making your own cabinet or speaker unless you are working off of a proven "project" or know a good amount about cabinet design and have the testing matierals and software.
You may be better off buying something designed for outdoor use.
Old 2nd February 2010, 01:18 AM   #3
Thanks Hons, I'm too much of a maker to just buy something....buying something isn't much fun. I'm not an artist, but I can follow direction. Just looking for advice on how to get the "proven project" information. The formulas are a bit above my knowledge, that's all. Jeez. Let me make a box, I'm the one that has to live with it.
Old 2nd February 2010, 01:59 AM   #4
Tom V is offline Tom V  United States
I bought a pair of Aurasound NS3-193-8A from Madisound to make a speaker bar for my computer (to be built real soon now). The Dayton driver is listed as a replacement for this. Madisound recommends 2 to 3 liters, sealed and stuffed. So that is what I am going to do. Should work for you too. -Tom-
Aurasound NS3-193-8A 3" Extended Range from Madisound
Old 2nd February 2010, 02:41 AM   #5
frugal-phile(tm)
planet10's Avatar
Nice little drivers. Bass kings for 3" drivers but at the expense of efficiency.
Gegg-the-Geek did a BR that got an amazing amount of bass out of them (mine were sealed)
dave
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd February 2010, 03:03 AM   #6
2 to 3 liters stuffed and sealed. Now that I can figure out. Thanks very much for your help! The ear will have to do on this one. Testing materials and software...maybe next time.
Old 7th February 2010, 08:14 PM   #7
Default Ghetto Fabulous!
Now that's DIY!
Aurasound 3" NS3-193-8A speakers in Kirkland Mixed Nut 2 liter enclosures, semi-sealed and stuffed with rotting foam bed pad, driven by the little Dayton DTA-1 T amp.
Seriously this was just a little test of concept for a computer sound bar I intend to build. Sound was pleasant and balanced, and best on axis in this nearfield application. The wife said "I can hear bass!", but then she was comparing to her laptop's built in speakers.
-Tom-
best sub for outdoor use soundhead Subwoofers 20 6th January 2010 08:50 PM
Indoor HDTV Antenna 45-50mile range? Bengali Everything Else 5 20th January 2009 06:08 AM
indoor lighting test with LEDS(pics) + need info on dimmers? JinMTVT Everything Else 28 26th January 2008 11:30 PM
Suitable chip for 12 volt indoor supply Winnie Chip Amps 28 16th September 2004 09:44 AM
Page generated in 0.08288 seconds (83.09% PHP - 16.91% MySQL) with 11 queries
