16 x b3s flat line array
Old 26th January 2010, 10:07 AM   #1
norman bates is offline norman bates  United States
norman bates's Avatar
Default 16 x b3s flat line array
Humble Homemade Hifi
"Each enclosure uses 16 of these drivers which results in a total cone area of about 480cm2 which is equal to that of a single 12 woofer while the ratio moving-mass Mms / drive force Bl remains the same. In this case a nice high acceleration factor of 935!.......... Once the loudspeakers are positioned correctly, they create a large spatial image with big dynamic shades. A sort of wall of sound filled with subtle details and nuances. If pin-point imaging is your thing, then maybe a different speaker would be your choice, but even so, this loudspeaker creates a realistic 3D picture in which all the individual instruments and voices can easily be pointed out. With good orchestral recordings there is not only good left to right imaging but also there is depth in front of and behind the speakers. The little full-range drivers produce a solid bass foundation, only the bottom 2 octaves are a little shy. So if you want to use these in a high-end Home Theatre set-up then I would advise to add an active sub-woofer. You can't expect everything from an 8cm full-range driver! The top-end of the spectrum is direct but never harsh, it reveals heaps of detail without getting over bright. It lets you take a deep look into the recording and takes you on a musical discovery journey."
Norman
Old 26th January 2010, 10:47 AM   #2
Colin is offline Colin  United Kingdom
Look very impressive but there's no way you're going to get them into your narrowboat ...
Old 26th January 2010, 02:20 PM   #3
italynstylion is offline italynstylion  United States
italynstylion's Avatar
What's in room low end response good till?
www.StereoClarity.com
Old 26th January 2010, 03:19 PM   #4
chris661 is offline chris661  United Kingdom
chris661's Avatar
Sounds like they go to 80Hz.
I'd be willing to bet they'll go pretty loud though. Good efficiency too.
My work: www.grimshawaudio.com
Old 28th January 2010, 12:17 AM   #5
I don't they will go too loud but much louder than well full rangers listen at.
The total area of 16 b3s are about the area of a 12" per side, with minimal xmax (short coil also).
But 16 drivers should add 12db for 92db 1w/1m, 1 driver measuring 79db by zaph.
Boosting 6db for baffle step eats up volume also (more modulation blurring the full ranger).
That's why I was thinking a 2' wide x 19" deep open backed box.
It worked well with my 4" tang band bamboos.............
Norman
Old 5th April 2012, 05:55 PM   #6
fakeout is offline fakeout  Canada
fakeout's Avatar
Norman
What's the minimum number of drivers you can use to create a line array?
Old 5th April 2012, 06:23 PM   #7
chrisb is offline chrisb
no controversy there
pick a number between 3 and infinity
kinda burnt out - taking a break
Old 6th April 2012, 03:05 AM   #8
Jim Griffin is offline Jim Griffin  United States
Fakeout asked: What's the minimum number of drivers you can use to create a line array?
If you like listening in the near field (why else have a line array?), then you can use my white paper to compute the height of the array to assure that you are listening in the near field.
http://www.audioroundtable.com/misc/nflawp.pdf
Old 6th April 2012, 11:04 AM   #9
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
It should really be floor to ceiling or a close approximation.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th April 2012, 02:24 PM   #10
Dave, floor to ceiling height is too imprecise. For example, your 8 feet high flat ceilings may not be my 10 feet high vaulting to 18 feet peak living room. The precise method is to place the listener in the near field so you can use information in the white paper to compute the line array height for your own situation.
For the usual 8 feet high room a 6 feet high array is adequate as you have some coupling to the floor and ceiling at the lowest frequency of interest. Even for my room with its higher ceilings a 6 feet high array is enough to place the listener in the near field across most of the frequency band.
16 x b3s flat line arrayHide this!Advertise here!
32 Hi-Vi B1S per 16 NSB in Line Array omarmipi Multi-Way 2 7th January 2011 09:56 PM
Hi-Vi B3S for Line Array? sdclc126 Multi-Way 18 16th August 2010 04:24 PM
A line array using HiVi B3S or B3N & Apex Jr tweeters? Brisso57 Multi-Way 6 10th August 2007 09:02 PM
thoughts on hi-vi b3s line array /w single tweeter Ignite Full Range 24 6th March 2005 09:25 PM
