Old 15th January 2010, 11:17 AM   #1
markusA is offline markusA  Sweden
Default Jordan jx92s ML TQWT's
I've just started the "burn-in" process of my new DIY speakers, a pair of ML TQWT's .
From what I've heard the jx92s really need a long burn in before they start sounding right.
At the moment it's a lot of midrange, a little sharp treable if exactly on axis and not so much bass.
Otoh I'm not using any baffel step correction yet so the weak bass is kind of expected. It's all there just not so strong.
Old 15th January 2010, 12:43 PM   #2
ra7 is offline ra7  United States
I would also check the stuffing. The jordans have plenty of bass, full and fairly low.
Old 15th January 2010, 12:51 PM   #3
Hi markusG, wow, nice! I just got a pair of JX92S's as well.
As I'm sure you know, they are designed by Ted Jordan for off-axis listening, so they will always be too bright on-axis.
(a) is that some kind of acoustic material on the wall?
(b) what are those tubes on the floor?
Old 15th January 2010, 01:00 PM   #4
Colin is offline Colin  United Kingdom
On axis they sound far too bright. They're meant to be 30 degrees out from the rear wall, to cross well in front of listening position. Depending on the enclosure design, they really benefit from BSC to balance out any thinness in vocals. Spoken word is a good test.
Those look very nice. Are they a variant of Peter Millet's TQWT design or one of your own?
And I'm guessing the cylinders are Musical Fidelity power amps?
Old 15th January 2010, 01:52 PM   #5
Before I do anything I plan to break them in properly.
If I can afford it I'll get some measuring equipment before I start tweakig them with stuffing and "filters".
rjbond3rd>Nah, it's just regular wallpaper looking that way. The Tubes are Musical Fidelity X-A200 monoblock's. They can drive pretty much any load...
(X-Ray CD and Nu Vista Pre-amp)
Colin>It's my own design based on an older version of Martin Kings spread sheets.
30 degrees and crossing well in front of the listening position? Well ok? I'll give it a try.
Old 18th January 2010, 11:42 AM   #6
A few days later...
They appear to be "warming up" but it's hard to make any definitve statement about the sonic qualities at this point.
I imagine the percieved audio signature will change drastically when I begin tweeking them with BSC.
The bass really needs a boost imho.
Old 18th January 2010, 04:16 PM   #7
It also depends on cabinet. GM's 48" MLTLs have, if anything, slightly too much bass (at least in my room).
Old 18th January 2010, 07:38 PM   #8
I suppose it also depends on what you want from a speaker.
The prototype BSC will be adjustable to allow fine tuning it. After I've tuned it I'll be making a more permanent and nice looking solution. This can take a while though since I plan on getting a measuring set-up.
Old 18th January 2010, 08:10 PM   #9
The baffle is 215mm wide in total but the edges are rounded with a 5mm radius.
Do I use 205mm or 215mm when clculating the BSC?
Old 18th January 2010, 08:44 PM   #10
frugal-phile(tm)
planet10's Avatar
215mm
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Looking for Jordan JX92S oshifis Swap Meet 3 26th September 2011 12:44 PM
jx92s ML TQWT powerratings and such? markusA Full Range 17 7th January 2010 03:14 PM
Jordan JX92s advice smallangryboy Full Range 16 13th October 2007 03:15 AM
Jordan JX92S Gaffer74 Full Range 11 31st May 2006 09:42 PM
Jordan ML-TL bookshelf? cheesehead Full Range 25 13th March 2005 10:29 AM
Page generated in 0.11127 seconds (76.35% PHP - 23.65% MySQL) with 11 queries
