Old 14th January 2010, 01:19 PM   #1
briandk is offline briandk  Denmark
Default Response FR202 - which enclosure
Hi
I hope you guys can help me. Which type of enclosure would you recommend for this 8-inch driver:
HIFI KIT - Response FR202.
I have translated some of the data:
Paper-cone
Impedans: 8 Ohm
Freq.: 39-18000 Hz
Efficient.: 95.5 dB/SPL
Fs 40 Hz
Vas: 57 L
Qts: 0.198
Re: 7.2
Le: 0.36 mH
Weight: 4.1 Kg
Would something like the Metronome or BiB be a good idea?
Brgds,
Brian
Old 14th January 2010, 07:28 PM   #2
InclinedPlane's Avatar
Xmax 1cm? Wow. I expected 1mm.
The driver will work in several types of enclosures; do what fits your design goals best.
I must confess my favorite music is that made by the Rolls Royce Merlin.
Old 14th January 2010, 07:48 PM   #3
the xmax is probably an error, ins't it? ain't an AN 8" castframe?
fine to see somebody is importing guidesound stuff directly in europe. Briandk what's the price in euro?
Old 14th January 2010, 08:47 PM   #4
hm is offline hm  Europe
hm's Avatar
Default Fr202
Hello,
i would prefer such a driver for
my Sat-horns:
Horn-Sat
Trumpet-Sat
Schalmei-Sat
and the double horns
Saxophon and
RDH20
http://www.hm-moreart.de
Old 14th January 2010, 09:42 PM   #5
i was comparing the specs. i was utterly wrong it is a different driver from the AN castframe. it has heavier cone, slighlty higher BL and sports an around 90db efficiency at 50hz?? also it has shorter VAS. ok i don't know what this all means... but it makes a different driver of it...
...can it be really a 1cm xmax? maybe 5mm one way?
Old 15th January 2010, 09:19 AM   #6
I think the price would be around 100eur/each incl.freight.
I will try them out and let you know how it turns out.
Brgds,
Brian
Fostex Fe103e blh recommended enclosure frequency response spacemen12 Full Range 5 9th June 2008 10:41 PM
Undivided Sealed Enclosure Response With Multiple Drivers... HsOffRoad Subwoofers 5 7th October 2007 02:59 PM
impulse response vs. enclosure size East Subwoofers 5 23rd February 2006 12:53 PM
enclosure dimensions and freq. response AudioGeek Multi-Way 3 9th May 2004 07:16 PM
Page generated in 0.07928 seconds (76.76% PHP - 23.24% MySQL) with 10 queries
