Old 11th January 2010, 08:01 AM   #1
tib is offline tib  Hungary
Default GM JX92S MLTL-48 from a D160mm drainpipe?
I'm just about to order a pair of JX92S. I'm wondering which enclosure design should should I build for it.
I guess GM's MLTL-48 will be the winner, and since it's cross-section shape may vary until its area remain unchanged I have calculated that its equal to a D=157mm cylindrical shape.
So I have a crazy idea to build it from a D160mm drainpipe like this: The Blanchford Group 6" Underground.
What is your opinion? (If the port tube can be made from plastic... )
Does this circular shape has some benefits over the rectangular or triangular one?
Maybe it would still require a box around the pipe, the voids filled with sand?
Old 11th January 2010, 05:56 PM   #2
Cool idea! The sand is a great idea. That should be a very solid cab.
Old 11th January 2010, 09:30 PM   #3
Colin is offline Colin  United Kingdom
A pipe is fine, a good strong structure. I looked at something similar (a cardboard former used in the paper industry) but the problem is mounting the driver into the curved pipe. A small section of coupling pipe? Would that introduce a cavity resonance? In the end the complication put me off but I'd be introduced to see what solution you arrive at.
Linkwitz uses a pipe section for his Pluto design - Pluto introduction
Given the stiffness of the cylinder shape, the extra sand/box section shouldn't be necessary.
Old 12th January 2010, 08:43 AM   #4
I would attach the driver to the side of the pipe, not the top.
And since it is made of plastic with some heating and pushing from inside a mounting plane could be crated for the driver.
Old 13th January 2010, 10:34 AM   #5
The trouble with that approach would be that it would constrict the pipe to almost half the area, around the driver.
I decided that the formers I found would be more useful as a central core to mould thin ply or bending-mdf around to create a D-shape cross-section out of wood. Add a flat baffle, then remove the core and cap off the ends. Failing that, I'm still on the lookout for a suitable aluminium or steel extrusion the right area and shape.
BTW, in case anyone is interested; the paper formers are the cores at the centre of large rolls of paper. They are about a quarter inch thick, up to four feet long and very solid. Most paper mills throw them away or give them to schools for craft projects. They'll usually give them away free. Cheaper than sonotubes from the construction industry but limited to about six inches diameter.
Old 13th January 2010, 10:59 AM   #6
Scottmoose's Avatar
Pluto is a (semi) omnidirectional design, rather than a regular direct-radiator so the upward-firing unit is part of the design. Goes with the turf. I don't think anyone here is proposing the same in this particular case.
Old 13th January 2010, 12:46 PM   #7
That is why I said: push the pipe from inside -> it will have an increased area at the driver mounting point.
T-Shape pipe connectors are also available, however I can not imagine the effect made by this little side tube... Maybe MJK would be able to model it...
One more possibility: use a corner connector at one end of the pipe and put the driver there. But again this needs a different design than MLTL 48".
This D shape from wood is a nice idea!
Old 13th January 2010, 02:25 PM   #8
Of course if you can get a large enough diameter plastic tube, you could just slice out a strip along the length and install a baffle. I did see some nice yellow tubes being used by the local water company but didn't get round to asking if they had any spare lengths.
Old 13th January 2010, 03:40 PM   #9
chrisb is offline chrisb  Canada
most plastic pipe products have elbow, T- junction & adapter fittings that should allow for easier install of driver(s), pretty much at your choice of location
http://www.t-linespeakers.org/projec...son/index.html
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 13th January 2010, 06:08 PM   #10
Oh, I can see that being allowed in the lounge ...
Has anyone rear ported the GM MLTL 48 ? batdan Full Range 3 15th December 2009 06:00 PM
GM JX92S MLTL-48 Triangle (JIT for UK Meet) Mr Chris Full Range 34 20th August 2007 12:46 PM
Bracing GM MLTL 48" blacklight Full Range 10 21st July 2006 03:29 PM
Veneering the JX92S GM MLTL LizardBrain Full Range 10 5th April 2006 09:31 PM
Pictures of GM MLTL-48? PrimaLuna Full Range 28 2nd February 2006 10:01 AM
Page generated in 0.12587 seconds (80.95% PHP - 19.05% MySQL) with 10 queries
