Finally got around to start building a pair of these for the CHR70 I purchased a few months back. I'm building the single driver versions in each cabinet and have my daughter helping me. Or maybe I'm helping her... She will take them with her when she goes back to college.
The sides are 11 ply 3/4 in wood from Lowes and appears to be void free and chamber, bottoms, tops and back are a red oak plywood that I had left over from another project. Local supplier for BB has closed their doors. Economy has not been kind to smaller lumber companies What do I use for lining and which sides do I put it on? What is best way to stabilize each speaker, sand or outriggers? Thanks, I'll probably have more questions as I get further into project. |
#2 |
Bruce,
I think that the sand in the bottom really helps. That's how I did mine and I've not had a problem with them tipping. I've been thinking about a small base for the Coniston cabinets since they are a a little higher. Maybe you could do something similar? Not sure how much it would change anything. PS: What was the lumber place that closed down?
www.StereoClarity.com |
#3 |
frugal-phile(tm)
Line as you would a bass reflex.
Minimally this means 3 faces of the inside of the chamber (ie top baffle 1 side) with 1 - 1.5" fiberglass. I line all sides with 1/2" recycled cotton felt. From there you can play with more lining or poly fluff stuffing. Whatever you do, do not block the ports. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Dave, are you talking about the pink fiberglass sold in rolls or something else?
Been gluing parts tonight. It's looking good and trying some different stains. My girl likes that grey stain that Ian444 put on his build. I'm also thinking about receiver or amp to use. She will source from a turntable or Macbook. I probably will give her my Sonic T to use but been looking at older "vintage" receivers that can drive these 4ohm speakers. Steven, Waxahachie Building Supply, Bought all the lumber from them to build my house 5 years ago. |
#5 | |
frugal-phile(tm)
dave
#6 |
All glued up except for one side. Drivers are in, running with macbook and
t- amp in garage and going to let them break in overnight and then put in stuffing and finish them up over next couple of days. Sound is pretty good as I listen to them to now in garage. Got that Canadian weather blowing in and it's freezing here in Tejas, I used to live in Chicago area not used to it anymore. |
#7 |
How about a couple of pics...mocked up and breaking them in
#8 |
Very nice!
#9 |
Finally finished these up before I sent them with my daughter back to college. They sound great sourced from my G5 to T-amp in my office.
She has a laptop and turntable so I found a mid 70's Sansui receiver for her for $50 to use that is able to handle driver impedance. It's a good way to go if anyone is worried about buying these speakers and also has a need for multiple source inputs. I think it may be all of 20 watts which is plenty loud. It was a fun build with my kid and a little more complicated that the TABAQ I did last year. For you astute viewers out there wondering if they lean a bit...you are correct. My woodworking skills are poor but the sound is terrific, and until they look as good as Axioms in pic all builds will be relegated to my office, garage or kids rooms. So,next time.... Measure 3 times not twice, cut all width dimensions on table saw at same time cause if you are a 1/16 in off, at least they are all the same and will glue up easier. I also need to buy more clamps and pick up a radial arm saw for length cuts. They are built to spec and Dave, if you are wondering, they are braced and have about and inch of pink fiberglass on 3 sides of chamber. |
#10 | |
frugal-phile(tm)
Maybe if we keep at him, we'll embarass Steven into putting in the brace. Sansui 331? dave
| Lotus BVR/CHR-70 - Question about suitability | BL21DE3 | Full Range | 37 | 3rd January 2010 12:55 AM |
| Seas Lotus drivers for sale! MAKE AN OFFER! | Spasticteapot | Swap Meet | 0 | 7th November 2007 04:59 AM |
| Using a Seas Lotus 12 inch | Stewart8989 | Subwoofers | 2 | 22nd May 2007 06:07 AM |
| FS: NIB SEAS Lotus SW300 subs | lethl_zo6 | Swap Meet | 0 | 16th April 2007 03:03 AM |
| Transmission Line / Seas Lotus...Help | 10K2HVN | Subwoofers | 8 | 6th February 2005 09:07 AM |
| Page generated in 0.12579 seconds (81.24% PHP - 18.76% MySQL) with 11 queries |
