why use CAT5 cable? - Page 2 - diyAudio
Old 30th December 2009, 05:43 PM   #11
wouldn't CAT6 be a better alternative then? From what I understand, CAT6 is better shielded, lower noise levels and also you can get cables where each strand are guaranteed to be the same length.
Old 30th December 2009, 05:58 PM   #12
mondogenerator's Avatar
plus that and the time delay you speak of, if not imagined by those that believe it; would be caused capacitively i assume, much like the 'buckets' in a BBD IC, and i would've though would be worse in CAT5, if what i said above is in fact correct...which i would believe is but haven't proved as yet
at any rate...increasing the 'seen' output inpedance of the amp is the absolute opposite that i would like to achieve, since i dont want to mess with my speakers QTS and hence tuning, electrically. If i did id make some field coils at work and knock the magnets off my speakers with a lump hammer, and experiment...
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 30th December 2009, 06:00 PM   #13
vinylkid58's Avatar
FWIW, many of use with full range drivers and tube amps are using a single pair of cat5 wires per channel, not several twisted pairs braided together.
Jeff
Old 30th December 2009, 06:20 PM   #14
oh.. thats pretty thin. a single pair?
Old 30th December 2009, 07:39 PM   #15
Alex from Oz's Avatar
Yep, thin but very effective. Sometimes less is more.
I use solid core Cat 6. I was able to get it for less than the Cat 5 (on sale) and the conductor seems slightly thicker than Cat 5 as well.
Alex
Old 30th December 2009, 08:00 PM   #16
frugal-phile(tm)
planet10's Avatar
Originally Posted by SY View Post
Right, it's the worst case. With a less-than-perfect voltage amplifier, the minuscule loss gets even smaller. And with normal tweeter impedance rise, smaller yet. I ran through those calculations in another thread.
Full Range forum. No tweeters. But the lower you can get the damping factor, the more any impedance rise at the top (& bottom) will cause an increase in power delivery just where the well mechanically damped FRs that prefer amps with high output impedance need a bit of help.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th December 2009, 08:08 PM   #17
frugal-phile(tm)
planet10's Avatar
Originally Posted by mondogenerator View Post
More importantly, as low as the capacitance may be, i cant help but think that the closer proximity of adjacent conductors would increase capacitance greatly, when compared to my 0.50/metre speaker cable which the conductors are spaced about 3mm apart....
unless you can get the CAT5 free
In my speaker cables i actually pull all the strands apart and space 2 single wires a couple cm apart on a piece of packing tape.
For a tidier cable, Chris took 2 seperate strands and spiralled them around a piece of plastic aquarium tubing crossing each other orthoganally.
And free is a common price for CAT 5. Leftovers from a network install are pretty common.
Try it. Or not.
dave
Old 30th December 2009, 08:08 PM   #18
vinylkid58's Avatar
Yes. It's all Dave's fault.
Right now I'm trying some mil spec stranded wire. 22g silver tinned copper wire, teflon coated with a silver braided shield, all wrapped in teflon shrink. This is very fancy wire compared to cat5, but I honestly can't hear any difference between the two.
Jeff
Old 30th December 2009, 08:12 PM   #19
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
according to what i know of inductors from winding my own, smaller gauge yields higher L than larger gauge wire; that is for a given coil diameter and length of wire.
I think only because of the fill factor - (you can get more thin wire in the winding space) which does not apply in this case.
Cat5 is probably fairly transparent to amps with low damping factor - some valve amps, but for grunty ss amps that want to move cones like solenoids, it will be a disaster.
Old 30th December 2009, 08:14 PM   #20
frugal-phile(tm)
planet10's Avatar
Originally Posted by planet10 View Post
No tweeters.
On the subject of tweeters. Some of the reasons for using such wire on a FR, makes it just the opposite with a tweeter & the typical bang in the most sentitive place XO points. The XOs often have a big impedance rise there which ends up with a bump in the FR because of higher output impedance.
Amp, speaker, & the cables connecting them always need to be looked at as a system.
dave
Questions about making Cat5 speaker cable wixy Everything Else 1 10th March 2007 06:57 AM
DVI video cable using CAT5 wire? montreal Digital Source 0 7th September 2006 05:20 AM
What speaker cable for Class-T amps, Cat5 MrDodo Class D 12 8th December 2005 10:44 PM
Cat5 Nappylady Multi-Way 27 31st March 2003 01:13 PM
Copyright 1999-2017 diyAudio
