why use CAT5 cable?
why use CAT5 cable?
Old 20th January 2013, 07:32 PM   #61
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Originally Posted by cogitech View Post
I suspect that my new tube amp (on the way) will like these cables, too.
What will it say if it doesn't like them?
jeff
Old 20th January 2013, 08:23 PM   #62
cogitech is offline cogitech  Canada
cogitech's Avatar
jeff
I don't know, but it'll be in a whiny tone.
I do plan to try it with both sets of cables, to see if things play out the same as with my SS amp.
Old 20th January 2013, 09:45 PM   #63
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
ive used 5 amp lamp cord with no issue on short runs. Dunno what AWG that would be, but for 12ft id think it would be ok, just. The gauge of cat5 isnt the issue to me, its the thin insulation and close proximity of conductors, and solid core, that concern me.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 20th January 2013, 09:53 PM   #64
vinylkid58's Avatar
Heeeeeelp meeeeeee!
jeff
Old 20th January 2013, 10:10 PM   #65
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
why use CAT5 cable?
The best dialectric for wire would be air (or a vacuum), thin is good in that respect. Given typical voltage levels the insulation is adequate. The thin, soldi core high purity wire is why you use it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th January 2013, 10:10 PM   #66
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
2 x 24ga copper conductors = 0.3ohms resistance one-way over 3.5m
Heeeeeelp meeeeeee!
Gladly. Shall we let this wretched thread about wire return to the obscurity in which it was deservedly languishing for over two years? Not only is it satisfying, you'll find it to be theraputic.
Old 20th January 2013, 10:15 PM   #67
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
why use CAT5 cable?
The standard formulas for CAT5 is either a single 2-wire pair or all 8 wires, solids to +ve and stripes to -ve. This provides reasonably low capacitance and inductance and resistance low enough to be tolerable with low-power systems. The various braiding formulas cause capacitance to go out of site and can cause problems with conditionally stable amps.
The lifting of veils thing smacks of placebo effect. Assuming that your original cables don't have wildly strange LCR characteristics, there should be very little difference in sound between those and your new CAT5 cables.
Bob
Old 20th January 2013, 10:54 PM   #68
cogitech's Avatar
The twists in the cable rule out cross-talk in digital signalling, so I can only extraploate that they would do the same with analog interference (as cross-talk is due to analog EMI of neighbouring wires.)
Old 20th January 2013, 10:58 PM   #69
cogitech's Avatar
Bob
Placebo, perhaps...
But how is it that I needed to adjust EQ after swapping cables?
Maybe I have actually lost enough in the bass that it sounds brighter, but I don't feel a lack of bass.
Some may wish to ignore the thread. I get that. However, I am not quite done exploring it...
Old 20th January 2013, 11:00 PM   #70
Scottmoose's Avatar
Oh dear.
OK. Here's one possible reason. I'm not saying it is the reason, it is just an example. When shifting to very thin wire, it's not uncommon for people to say they have found an apparent improvement in the midband & HF. One cause of this are conductors that are too thin to handle LF current demands, and thus their dynamic peaks are more or less subtlely compressed while the higher frequencies are of course left relatively unaffected, thus subjectively emphasising them over the lower registers and making them sound clearer.
why use CAT5 cable?Hide this!Advertise here!
Questions about making Cat5 speaker cable wixy Everything Else 1 10th March 2007 06:57 AM
DVI video cable using CAT5 wire? montreal Digital Source 0 7th September 2006 05:20 AM
What speaker cable for Class-T amps, Cat5 MrDodo Class D 12 8th December 2005 10:44 PM
Cat5 Nappylady Multi-Way 27 31st March 2003 01:13 PM
Copyright ©1999-2017 diyAudio
