Two years ago, I bought a pair of Fostex FE207E drivers for testing.
My first enclosure was a rear-loaded horn (pictured) per Fostex design instructions. I also built a vented cabinet for listening. Both enclosures sounded awful. The sound was dry, lifeless, and with absolutely no soundstage. I have tried a variety of amplifiers: the Pass Zen v4, a hybrid Akikdo/MOSFET amplifier, tubed amplifiers (i.e. monoblock EL84), commercial amplifiers, and even the S-5 K-8LS. None of these configurations have sounded good. Any suggestions? |
#2 |
frugal-phile(tm)
That looks like a BK-20 horn (not a Fostex Factory Design). Even when built as intended from plywood, and using the appropriate driver (one of the 3 8" fostex suitable for horn loading), it is not stellar. And stuffed as shown, it is likely a badly tuned aperiodic box.
I would also be leary of the Fostex recommended BR. Add in the material you built these out of, and i'm not surprised with your take. The 207 is not without its problems, but i would not call it awful -- even in a stock state. How many hours on them? If you don't want to try for 3rd times a charm and put them in a proven box, it shouldn't be hard to sell them. The boxes should go into the tip thou.(sorry if that sounds a little hard) Have a read thru the Curvy Chang thread. dave BTW: i really like what you've done with your EL84 monoblocks (i'd be using ECC81 on the front end thou)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Hi Kashmire, that cab looks like a Fostex BK-201 variant which is more oriented to the BLH-friendly drivers like the FE206E. I'm not sure that combo can be saved.
I see on your site that you also did BR and sealed, and were not happy. (Sealed will not go very low, obviously). 1. Did you use a baffle step circuit on the BR? If so, did you use a bypass cap (FE207E rolls off above 14k). 2. What kind of music are you listening to? Certain genres are better than others. I have heard this driver sound excellent in the two FE207E designs on this page: Products EDIT: Oh planet10, you are too fast! |
#4 |
#5 |
I wouldn't give up on the driver quite yet. I have both a set of curvy changs, and a set of brines FB20 cabs that I built myself, both using the FE207. Both sound extremely good. The changs have phase plugged drivers (which I strongly suggest having heard the driver side by side with and without) and obviously throw a bigger soundstage. The brines cabs are also excellent in their own right, but really need a sub under them. I agree with dave in observing that your first problem is your cabinet material. It just does not add up........good drivers, good amps, and $5 a sheet cabinet material will always equal poor results. On a side note, if you're looking for a driver to put in a horn the FE206 is a much better choice, so maybe selling the 207's is best. I might be willing to grab from you them as backups, for the right price of course.
#6 | |||||||
Hmmm ... surprising comments about the enclosure materials. It is a mixture of 3/4" resin particle board and MDF (the baffle, rear panel, and internal baffles are MDF). I wouldn't except the cabinet material in this case to be playing such a prominent role. In my opinion, there seems to be other obstacles to overcome before optimizing the cabinet materials.
I lost the build sheet for the horn cabinet a couple years ago. It was in metric, and it was a headache to translate all of the measurement to my english table saw. The prints were branded Fostex. The BK-201 looks awfully familiar. Maybe what I have is a simplified BK-201. If that's the case, the FE207E isn't the best choice for horn loading. However, I just haven't had much success with sealed or vented. I roughed up some boxes using particle board, MDF, and PVC pipe (for the vent) for testing. Quote:
I moved the amp to my main system. The preamp delivers a bit more voltage, so now I don't need as much gain. I'll be switching back to the 12AT7 soon. All it takes is a few resistor changes at the plate and cathode. I like the 12AT7 more anyway, because I can run more aggressive and hotter plate currents than the anemic 12AX7 1.2mA. Quote:
Thanks for your comments thus far. I'm coming to the opinion that the FE207E is not my friend, and maybe a different choice would have been more appropriate. What about dipole operation? Since I'm already using dipole woofers, is the FE207E a complementary candidate? |
#7 | |
frugal-phile(tm)
dave
#8 |
Looks like a thick front baffle you have there. Did you round over the driver holes from behind?
#9 |
Hi Kashmire, if you put the FE207E into a BR (or MLTL) with no circuit, it's not going to be balanced (i.e. it will be too forward, lacking bass unless the cabs are flush against the wall). The circuit compensates for the tendency of lower frequencies to "sneak around" the baffle, radiating in an omni pattern (thus dipping ~3-6 db depending on distance from the wall compared to the mids and highs which radiate all their energy forward due to the width of the baffle). Search for BSC or "baffle step compensation".
The FE207E will not have much bass in an undersized BR but in the right sized BR or MLTL, it can play down to and below its Fs of ~40Hz. But that circuit is key. Circuit is just a resistor and coil in parallel, optionally with a cap, which is placed in series with the + on the driver. It basically cuts above a certain frequency, but the cap eliminates the cut at very high frequencies (putting the sparkle back in). It could be that you are missing the frequencies above 14k with this driver. The BSC gives you the opportunity to handle that as well -- cutting the midrange and then using the bypass cap of whatever value lets you effectively "boost" the treble in relation to the midrange. Still, a supertweeter is a better solution if you need to play up to 20k. Don't let this one driver sour you on single-driver though! I'm playing with the Mark Audio CHR-70's and they are as different as can be, and only $70 a pair. Not as efficient but lots of fun. |
#10 |
I thought that the 207E was just a shielded version of the 206E. The 208 Sigma cabinet is a good match. I made mine 3 years ago and will never need to build another speaker.
| One Fostex FE207E, (1 or 2)xFE167E, or (2 or 4)xFE127E? | goldorak | Full Range | 118 | 27th January 2010 02:10 PM |
| Fostex fe207e in 36l box | quiet fish | Swap Meet | 0 | 12th July 2009 05:25 PM |
| Wanted: Fostex FE207E | rhart | Swap Meet | 0 | 9th February 2006 05:06 PM |
| Fostex Fe207E and horn | johnb | Full Range | 2 | 20th January 2005 11:32 PM |
| Fostex FE207e vs. FE206e | Kashmire | Full Range | 0 | 15th January 2004 04:18 PM |
| Page generated in 0.13321 seconds (83.64% PHP - 16.36% MySQL) with 11 queries |
