Old 27th December 2009, 04:37 PM   #1
Default Calculating volume enclosure for 2 speakers
Hello and Merry Christmas to all! I have found a few online enclosure volume calculators but they only work for loudspeakers consisting of 1 driver. My aim is to make a common cabinet for 2 drivers of the same kind. Can you help me? Should I double some parameters and calculate with them as if it was a single driver?
Old 27th December 2009, 05:22 PM   #2
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
I believe you can take the result given for one driver and double it when using 2. ie, a suggested single driver volume is 20L, to use with 2 drivers assume 40L
These are sealed boxes I presume?
Old 27th December 2009, 05:49 PM   #3
frugal-phile(tm)
planet10's Avatar
You can double the Vas, halve (or double) the Re and work with that. Most calculators don't need more.
Martin King has an article on his website that goes into it in greater detail.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th December 2009, 05:49 PM   #4
If you are designing your own speaker, you should get, and learn how to use, WinISD. It is free, and not hard.
Joe.
Old 27th December 2009, 06:06 PM   #5
Scottmoose's Avatar
It's also not particularly representative, unless you know exactly what you're doing. Although I still use it for quick checks etc. so I certainly wouldn't be without it.
Short version =
With drivers in parallel, Vas & Sd double. Re, Le /2.
With drivers in series, Vas, Sd, Re, Le & B*L all double.
Vb doubles with two drivers, as noted.
Old 27th December 2009, 06:14 PM   #6
Why do you say this, and what would you regard as better?
Joe.
Old 27th December 2009, 09:52 PM   #7
Scottmoose's Avatar
Any number of reasons, and 'better' is dependant on exactly what it is you want to be doing, to say nothing of your own background knowledge. It's a neat little piece of software (with a few bugs), but it's also very basic, and does not take many issues into account. Standing waves are not considered (its BR calculations are pure Helmholtz resonance, and life is rarely so simple -if you're planning a tall, thin floorstander it's unlikely to be accurate). It also provides anechoic data, & therefore, you have to take this into consideration. For e.g., a QB3 anechoic alignment in practice is likely to end up anywhere from +3dB to + 6dB below 100Hz in practice due to room-gain. Baffle-step loss is also not taken into account, nor is edge diffraction & host of other issues.
All of which makes it sound as if I'm down on it -I'm not, it's useful, & many other packages have similar issues, but it's limited, and like any software, it's just as important to know what it doesn't do as what it does.
Old 28th December 2009, 06:47 PM   #8
chris661's Avatar
I suppose the knowledge of how it will interact with your room is part of experience.
I found, for Visaton users only, Boxsim was quite good - it does baffle step, frequency response, and seems to take into account the tall, thin floorstander idea. It also has sliders for stuffing in different locations. Like I said, it's only for Visaton speakers.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
calculating volume NineEleven Car Audio 1 16th September 2009 01:20 AM
Calculating enclosure volume for TL Kensai Full Range 8 15th February 2008 04:49 PM
Calculating For Cabinet Enclosure Space speedemon Multi-Way 24 23rd April 2007 03:47 PM
Calculating Cabinet Volume? kestrel200 Multi-Way 10 16th January 2005 12:23 PM
Calculating volume - bandpass enclosure avatar307 Subwoofers 6 14th December 2003 01:59 AM
Page generated in 0.08189 seconds (83.50% PHP - 16.50% MySQL) with 10 queries
