First DIY build - wall mounted speakers for T-amp? - Page 3 - diyAudio
Old 12th January 2010, 08:16 PM   #21
There was a project by Jacques Candé who I believe is French Canadian some years ago which was a flat, square, wall mounted transmission line which was split into four quadrants. IIRC it used the Fostex FE127.
Perhaps you could try to find him.
He also built a pair of Nagaoka Swans which he was trying to sell, again some years ago.
Edit.
From 2005
http://www.quebecaudio.com/forums/in...howtopic=4786&
I guess he hangs out here... or did at some stage.
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 12th January 2010, 09:19 PM   #22
frugal-phile(tm)
planet10's Avatar
Originally Posted by Andrewbee View Post
Jacques Candé ... which was a flat, square, wall mounted transmission line which was split into four quadrants for the Fostex FE127.
Here is the document that would have been at the now broken URLs.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th January 2010, 01:37 PM   #23
Thanks Dave
I have a copy of the doc amongst my audiofile (pun intended) but where exactly in the piles I have no idea. I was going to look for it to scan and post but you saved me.
I was always intrigued by this design and considered building it but could not think of a way to make it unobtrusive.
Andrew
Old 13th January 2010, 02:24 PM   #24
...could not think of a way to make it unobtrusive...
My thoughts exactly! All-speaker-no-wall. Maybe something for when I have a house the size of a castle.
Old 29th January 2010, 03:14 PM   #25
Thanks again folks - have ordered some Mk1 CHR-70s from Stereo Clarity... they are in transit!
Question regarding wall mounting the CHR-70 wallMount 0v99 design. What's the recommended approach?
Would keyhole mounts be the best way to attach to the wall? Or picture hooks and felt tabs like this Zaph Audio design - Zaph|Audio
Or even something to separate the speaker cab - e.g. http://www.curbly.com/chrisjob/posts...er-wall-mounts
Old 29th January 2010, 03:51 PM   #26
chrisb is offline chrisb  Canada
Or even something to separate the speaker cab - e.g. How To: DIY Speaker Wall Mounts. » Curbly | DIY Design Community « Keywords: speaker, Stereo, wiring, Music
If you don't need any directional adjustment, how about a "French" cleat ( mating 45` beveled strips) mounted on the wall and along the top of enclosure back panel? Using 3/4" or so stock should allow room for cable dressing if the input terminals are rear mounted, and a small block on the bottom of enclosure would keep it from rocking.
Hopefully, the desired locations will span at least one wall stud, if not butterfly or Zip-it wall anchors work very well in drywall panels, (NOT so much in older style lath and plaster)
Love: a constellation of vital phenomena - organization, irritability, movement, growth, reproduction, adaptability
Anthony Marra
Old 29th January 2010, 05:05 PM   #27
Originally Posted by chrisb View Post
...how about a "French" cleat ( mating 45` beveled strips)
Ingenious! Thanks! Looks like the ideal solution (and no messy routering for keyholes).
RE: directional adjustment, is it just a case of wait and see, or would you expect these to need some toe-in?
I seem to remember reading that full rangers were pickier than multi-ways regarding spacing/placement....
Old 29th January 2010, 10:05 PM   #28
That's very dependent upon the room & location of primary listen window, and of course is a big disadvantage of fixed wall mounted speakers, whether bolted on or installed in wall cavities / soffetts. This can work fine for surrounds in dedicated HT systems with fixed seating positions - but for 2 channel combined TV and audio systems, it can severely limit "optimal" listening positions.
Yes, simple full range systems and small stand mounted "mini-monitors" can have placement criteria that don't easily reconcile with WAF / space considerations.
Anthony Marra
Old 10th February 2010, 04:47 AM   #29
bearberry's Avatar
Default Commercial alternative
French cleats are an excellent approach, easy and cheap, but if you do need adjustment:
Buy Speaker Bracket - Black (Max 33LBS) - Set of 2 online - Speaker stands and mounts - Mounts and Stands
I have a pair, not in use yet, and they seem well-made. Rated for 33lbs each.
bb
Old 29th March 2011, 11:05 AM   #30
Default Flat Wall Mounted Fe127e
Hi
I am the Jacques Candé mentioned in this post.
I am not Canadian but French. However, I do not live in France but in the Netherlands.
Back to this project I would like to say
It is very musical and was taken by a good friend for this quality.
Bass output suffers from two deficiencies:
1-The ports are too narrow to allow a decent sound level at 50 Hz equivalent of that of the driver. Today I am convinced that a single port 4 with proper dimensions is better.However, I understood this long after having built up and sold the boxes.
2-The baffle step still exists although the box is leaning against the wall.
Further the Baffle step response is very pronounced and tortured owing to the central configuration of the driver in the box.
Too make it short, I was very wrong when I had this idea and do not advise you to do it.
Note that I am sorry to write this.....
In short the best simple speaker I ever made was this project see attachment:
It has a good smooth response and reasonable dimensions, with a demonstrated WAF.
Have some good time.
Jacques Candé
Flat wall mounted speakers CCU Multi-Way 9 10th September 2009 06:05 AM
Wall mounted "fullrange" speakers BjoernBach Multi-Way 3 27th February 2007 06:07 AM
Small, wall mounted open baffle? GuyPanico Multi-Way 5 10th November 2006 06:49 PM
Posted design for wall-mounted speaker Zaph Multi-Way 1 21st July 2005 09:43 PM
DIY wall-mounted speakers Donut Multi-Way 4 16th September 2002 06:10 AM
Copyright ©1999-2017 diyAudio
