The One and Only Full Range AMT - Page 3 - diyAudio
Old 10th December 2009, 01:46 PM   #21
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
Very interesting, any idea on what something like this might cost?
Old 10th December 2009, 02:04 PM   #22
The cost will depend on several factors..
I tried to get most of the parts (except the diaphragm) manufactured in China / Taiwan, but I was not able to get the quality I wanted.
I ended up with production of the metal parts in Norway (and bought special stamping tools to get the needed quality), the holding / folding box for the diaphragm are made by a German company by 3D CNC and are made of "pertinax".
Only the neodym N52 magnets are manufactured in China.
You then add Norwegian labour cost for the assembly of the parts..
As it is now the AMTs will be expensive...
Old 10th December 2009, 02:25 PM   #23
Hi Ray!
Congrat´s with this extremely interesting project. Looks for sure very promising. Have you had a chance to measure distortion (k2, k3...) for this unique driver? What is the sensitivity?
Karsten
Old 10th December 2009, 02:52 PM   #24
Originally Posted by Karsten Sømand View Post
Hi Ray!
Karsten
I have to make new measurements on the final version of the AMTs,
but the sensitivity will be between 90 and 96dB as I can choose some levels of the magnet field strength.
On the prototypes the strongest magnet field gave best sound quality when listening, but the worst measurements - so the sensitivity will be decided next week.
I have also designed a wave-guide for the AMT that will increase the sensitivity with some dBs and give better directivity.
The distortion on the prototypes when measured at 100dB @ 1 meter was -45dB (2nd) and -56dB (3rd).
Old 12th December 2009, 11:28 AM   #25
There are some myths regarding AMTs - high temperatures of the diaphragms are one of them - with some amusing explanations..
When I designed my AMT I designed them to manage high temperatures and they can operate at up to 200 degree Celsius..
But when I measured temperatures I only got 1 to 2 degree temperature rise from the ambient.
I investigated both mine AMTs and several other brands and I found the reason for this "problem".
The traces of the "coils" shorts due to poorly quality of the folding of the diaphragms or driving the diaphragms above Xmax.
On the Heils and copies of those there is possible to have major shorting and even sparks can be seen...
That this results in distortion should be obvious.
But when measured with as an example Arta software this clearly audible distortion are not clearly shown...
I used an high power heat blower and heated the diaphragm until its shape became distorted and parts of the diaphragm was shorted.
Now It sounded highly distorted and the distortion / noise was more dominant than the audio....
But when measuring with Arta there was still not show any obvious differences on distortion....
Old 12th December 2009, 02:24 PM   #26
49 - for the 19th time!!!
c2cthomas's Avatar
Hmmmm.... in my old QC days we would "cook" things for 24 hour - but it was only at around 93.3 Celsuis (200f). The vibration table (shake - rattle - n - roll) was always fun to watch (from behind the protective bullet proof glass). But those days are long past and the only way I have to simulate those temperatures now is when SHMBO gets upset at some of my antics - followed by a few hours of a very chilly atmosphere.
I knew one of the guys at ESS that came up with the fixture to fold the diaphragms (if I remember his name was Robinson - not sure tho - it's was 35 years ago). It is the folding of the diaphragms and then their "mating" with the holding frame that was very difficult to do at first. They (ESS) did finally get it developed to a level that was acceptable in a QC fashion - but there were a lot of lessons to be learned along the way. That is usually the way things happen in the world of making something on a production line - a bit of trial and error to get things put right - especially so when fooling around with stuff that has not been done before and is a new technology.
To get your diaphragms to operate at these temp's and remain reliable is a great accomplishment - Congratulations!
DIY audio can be expensive – but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 12th December 2009, 05:23 PM   #27
Overkill Audio's Avatar
Talking Potentially "Disruptive" technology...
Hi Ray,
Quote
"I used an high power heat blower and heated the diaphragm until its shape became distorted and parts of the diaphragm was shorted.
But when measuring with Arta there was still not show any obvious differences on distortion.... "
99% of all commercial audio is designed and then marketed by "technicians" who don’t know what behaviour / properties to measure or how relevant these are to the goal of life like sonic reproduction.
Clearly you are in the rare 1% group of designers ( not just a technician) who do know what to measure, how to measure it and how relevant the data is.
Congratulations on developing potentially "disruptive" loudspeaker technology.
I hope your huge effort and commitment will be rewarded financially, how (or if...!) you do will depend on many factors, including :
(1) Reducing manufacturing costs to a point where mass market production and sales will be attractive to VC companies / licensing to a PLC.
(2) Defendability of your patents, IP and trade marks
(3) Broad base appeal i.e. on wall and in wall home cinema, commercial premises - restaurants / bars etc, licensing to loudspeaker manufacturers.
Small niche markets like DIY or high end audio are only useful to "prove your case" and strengthen your negotiation position with the big PLC licence deals.
Many more things too but I just wanted to give you a heads up cause you seem to have a tiger by the tail, and they can bite...!
"Keep your friends close and enemies closer" ...
Good luck and once again congratulations on getting this far.
All the best
Derek.
Old 12th December 2009, 06:36 PM   #28
c2cthomas's Avatar
Derek.
Old 13th December 2009, 10:06 AM   #29
StigErik's Avatar
*Great* work Raymond!
I hope you will be able to put those into production. What about discussing the matter with Beyma or Mundorf?
Looking forward to see more detailed measurements, especially off-axis SPL. How low do you think they can go without baffle? (in a baffle-less dipole).
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 13th December 2009, 04:33 PM   #30
Thanks for all replies in this thread!
Attached a measurement @ 75 degrees...
The measurement is done in my listening room that have 60 cm thick concrete walls with 25 mm solid oak "panel", the floor are 25 mm solid oak and are floating on "mother earth" via 5 cm compact isolation, the roof are three layers of sheetrock and one layer of MDF and there are no curtains, no absorbents, no damping at all..
The measurements done here get some extra peaks and bump due to the undamped room - listening is great as long as proper equipment are used.
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
5.25 full range boxcustom Full Range 0 20th March 2007 09:33 PM
Full Range jered22 Full Range 2 12th January 2005 11:16 PM
Copyright ©1999-2017 diyAudio
