Hi to all
I would like to ask if it is possible to change FE167E with FE207E in a BIB enclosure with dimensions 31cmx42cmx168cm without critical sound changes. |
#2 |
No time to do any Vp checks, but you'll probably loose a bit of LF gain due to the pipe being acoustically smaller than ideal; might balance out a bit though due to the higher inherent efficiency of the 207. Depends on what exactly it is you're trying to do.
#3 |
My BIB's are 30x48x167 cm , originaly for Lowther DX3.
One day I tried some Fostex FE207e's and they , at least in the lows , sounded beter then the Lowther. Maybe also a little room dependent. Just give it a try, you want be disappointed. warmest gretting Leon.
Leon |
#4 |
Thanks Scottmoose and Leonidas for the advice.
The experiment i want to check is to lower the LF.I attach a picture also to have an idea about room space and position of speakers.The problem is that i have to cut a bigger hole on front baffle to fit FE208E, so if the result is disappointing will be the of enclosure. |
#5 |
this is the picture
#6 |
huge pipe - 207 should have half the cone displacement for same output
#7 |
Finally i followed leonidas advice and i replace the fe167e with fe207e.From the first note the bass is much better than before.It is more deep and tight . Listening to a cd with several kinds of drums, with a reasonable volume, i felt the bass in my chest.The only thing now is to wait for "break in", for mid and high's.
#8 |
'Sounds' like all you really needed to do was add some series resistance to the 167, but 'BIB' rules for driver size too where improving the quality/quantity of its (mid) bass output is concerned.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#9 |
CGIAN ,
Glad you like the bass output. Mid and high's improve over time. I'm 58 years old and don't need it, but if you are younger , maybe you need a tweeter. The fostex FH17 will do the trick. Experiment with a C around 0,5 ~ 2,2 uF in series with the FH17. A friend of mine did so and even I hear some more "air" in the sound. Good luck and enjoy the music!!
Leon |
| Change between FE167E and FE207E | cgian | Full Range | 0 | 4th December 2009 08:55 AM |
| Fostex fe207e in 36l box | quiet fish | Swap Meet | 0 | 12th July 2009 05:25 PM |
| FE207E Specs | Bob Brines | Full Range | 5 | 30th April 2009 03:00 PM |
| WTB: Single FE207E or PX for 2 x 166/167 (UK) | phresh | Swap Meet | 0 | 7th April 2009 12:54 PM |
| BSC for MLTL FE207e | afunkymonk | Full Range | 8 | 30th January 2009 11:53 AM |
| Page generated in 0.09669 seconds (72.10% PHP - 27.90% MySQL) with 11 queries |
