Old 3rd December 2009, 07:58 PM   #1
Coreyk78's Avatar
Default Pioneer B20 in a sealed stand mount
Hi all, I have read a lot of the threads on the forum here about the Pioneer B20FU20-51FW but I don't know if I found them all since the search tool won't accept 3 character search terms. So sorry for yet another B20 thread but I didn't know where to put my post.
I want to build a nice little cheap project using some Pioneer B20s loosely following Godzilla's sealed design. Rather than building tall floor standers I was thinking of building some short and fat standmounts with internal dimensions of 22"H x 9.75"W x 10.5"D which would give me 1.3 ft^3 like Godzilla used. I would like to use the goldwood piezo tweeter, but mounted on the front of the cab with an 8 ohm resistor and crossed somewhere between 6-10khz. Bass extension below 80hz is not important to me, I have a sub to fill that in.
Any reason why this box shape absolutely wouldn't work? Otherwise I'm going to go ahead and build it with some 3/4" MDF, worst case if it sounds bad I can build different cabinets and scrap the short and fat ones.
Old 3rd December 2009, 10:32 PM   #2
I used similar dimensions in a 1.3 ft^3 sealed cabinet and was rather dissapointed with the sound of the B20s. Muddy bass, low SPL, and nonexistent highs. Not a fan of the B20s.
Mitch
Old 3rd December 2009, 11:10 PM   #3
norman bates's Avatar
Well, once you put some loose cotton balls between driver and whizzer, and I had it in a large empty sealed box (qtc .577 or 1' deep x 2' wide x 3' tall) I loved it. When I had it in a smaller 1.7ft3 sealed box with sand filled walls, it was shouty and more cupped, more saxophone honky, echoy sound. I think the smaller enclosure size had everything to do with it. It was the same driver.
I had better results trimming 1/4 of the whizzer off but then I had to boost the highs even more with a 10 band eq, but it was less echoy than the un trimmed whizzer with no eq.
But many seem unable to deal with a larger box.
Once you push the baffle step low, it sounds much better.
Norman
Old 4th December 2009, 04:27 AM   #4
Godzilla's Avatar
Single Driver Website
I used the B20 in a .75 cubic foot box and it sounds good. piezo on front just like you want too.
some love this driver and some dont... i think its a good deal.
Godzilla
Old 4th December 2009, 12:19 PM   #5
Coreyk78's Avatar
Godzilla
Thanks for that link Godzilla, it appears you already built exactly what I was thinking of.
Old 4th December 2009, 03:37 PM   #6
gychang is offline gychang  United States
I am also very fond of B20 speakers, recently I finished a test version vented as detailed here: Dark Vador speaker!, test version
I am very interested in coupling with the piezo tweeter (I have several in the garage) also. B20 indeed is worthwhile project, I agree it has a nonfatiguing sound once the size of vent is figured out correctly. I am very interested in all projects with B20...
gychang
Old 4th December 2009, 03:39 PM   #7
badman is offline badman  United States
Custom Title
badman's Avatar
I used this in a 25L box, tuned to 25/30 with a slot port. Worked well to give a little BSC boost. The driver absolutely needs a supertweeter to my ears, however.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 4th December 2009, 04:58 PM   #8
any pictures and details of BSC boost?, I totally agree B20 needs supertweeter above 10K.
gychang
Old 4th December 2009, 05:18 PM   #9
Coreyk78's Avatar
gychang
Hi gychang, reading some of the other threads that you were involved in is what convinced me that I wanted to try out the B20. I find that I generally prefer a more laid back sound so I'm really excited to hear how they play. Plus the low cost is a definite bonus! I can buy all the parts to build a pair of speakers for just a little more than a single Fostex FE207 driver
2 way, front ported, stand mount, HELP nordhaven Multi-Way 4 8th March 2008 01:33 PM
Want to build a sensitive 2 way stand mount wixy Multi-Way 29 13th November 2007 01:11 AM
Looking for two way stand mount for T27 tweeters fin1bxn Multi-Way 2 11th August 2007 11:49 AM
Stand Mount 2-Way Low Distortion Monitor bssk Multi-Way 2 4th November 2006 01:52 PM
MTM stand mount or floor stand garfieldcat Multi-Way 5 7th July 2004 12:45 AM
Page generated in 0.11789 seconds (78.00% PHP - 22.00% MySQL) with 10 queries
