Old 1st December 2009, 07:03 PM   #1
matherp is offline matherp  United Kingdom
Default How to inset Fostex drivers?
Hi all
Can anyone please advise a relative beginner in the woodworking department how to neatly inset Fostex drivers so they sit flush. Why can't they make them round?
I've got the usual tools including bench-mounted or hand-held router but without making a jig by hand or having a dead driver to use as a template I'm stuck.
Any suggestions gratefully received
Best regards
Peter
Old 1st December 2009, 07:39 PM   #2
Ty_Bower's Avatar
http://s69.photobucket.com/albums/i4...u/P1120683.jpg
They don't mind sitting face down on a flat surface. Could you try tracing the outline of the basket onto the face of the baffle, then cut it out with the router by hand? Maybe stop 1/16" shy of your pencil line, then go back with the sanding drum on the Dremel tool to clean it up.
Old 1st December 2009, 08:11 PM   #3
scottmplsmn's Avatar
Trace the driver frame outline onto a piece of 1/2" x 12"+/- x 12"+/- mdf using a 1/8" shim between the frame and your pencil. Cut out the opening leaving waste on the cut side of the line. Use a rasp / file to get down to the line. Fit a 1/8" offset template guide to the router base and chuck a straight cutting bit into the router. A plunge router is nice but not necessary. Set the router for a cutting depth equal to the frame thickness. Clamp the template to a piece of scrap and do a trial cut. The advantage is you only need to get the template right once, and then you can do multiples.
Old 2nd December 2009, 12:28 AM   #4
http://www.exquisiteaudio.com/baffle.html
I should add - make sure your bit is centered to the base of your router, of course it should be but its worth reminding you of.
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 2nd December 2009, 04:33 AM   #5
You can also, use top bearing bit and make the template opening just 1/32" bigger than the drivers frame.
Old 2nd December 2009, 04:43 AM   #6
I think it was 6 inch or 6.5 below which flush mounting does not accomplish anything. That was the advice from GM, a regular here. So how big of a speak will you be using?
I tried this free hand for the Fostex 127e: did the tracing and tried to steady up to the
line but there is a lack of control.
The system from andrewbee looks to be a good one. There is another and the process is documented in text at a thread called flush mounting the whole story from some time back. Try search for that if you want to make templates. Or I can look for it-- it was my thread but I am lousy at using search on this site.
Let me know if I should go look it up.
Old 2nd December 2009, 04:32 PM   #7
chrisb is offline chrisb  Canada
there's always the option of having a brilliant CNC operator with a few minutes on his hands to write programs (for both the driver opening and flush mounting rebate) at the control panel, then save them
Would there be any interest in CNC routed templates for use with pattern following router bits? I currently have patterns available for the 3" , 4" and 6" Fostex drivers.
After cutting your driver opening with hole saw or router jig, you drop the driver in place then fit/align the template outside of that. It's probably a lot easier to complete the routing before cabinet assembly as it allows you to clamp the template and work piece securely to the bench - even though you're only removing approx 3-4mm depending on driver, you can't be too secure.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 2nd December 2009, 04:43 PM   #8
frugal-phile(tm)
planet10's Avatar
Chris & i have discussed this and we could certainly do it. Templates could be purchased, or maybe even rented (more complex, but many people likely only need to use the template twice). i would consider that rent be paid to diyA as a donation.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd December 2009, 05:52 PM   #9
I have thought about doing this for a long time but don't have a blank Fostex to do the pattern making which I thought necessary.
Though I've studied the procedure over and over since it was printed in Speakerbuilder, I have one question. How does the template get centered properly after the cutout is made? Cutout is made by using the diagonals and finding the center then use a circle jig or hole saw to punch out the hole. How is the template positioned and do you have any pics of the work on your projects for 4" 6" etc? The pattern has to be in a frame and the frame would have to be centered and then properly clamped or screwed in place to prevent wobble. Some kind of registering system as is done in printing with color overlays would be necessary.
Old 2nd December 2009, 08:17 PM   #10
All of my own projects were made with CNC machined baffles, so I don't have any photos of the procedure described below, but I have thought of how I'd go about it.
There was one project on which I free-handed the rebate - even if you pre-score the outline with a veneer knife around the frame of a mounted driver, it's just too easy to mess that up.
There are a few photos of finished projects here:
Meet the Fonkens
All of these (except the solid bamboo plywood, and the edge grain fir cabinets with radiused edges, built by Scott Dunn) were veneered after assembly, and the driver /port slot cutouts hand trimmed.
The template would be either 1/2" or 3/4" MDF, and oversized to allow for clamping, or even screwing to the work surface.
Assuming that you're routing the rebate separately from the driver cutout, and before the baffle is assembled into the enclosure:
- use some spacer blocks for the first couple of steps;
- install the driver and align either by eye (just kidding) - use a T-square to align the screw mounting holes on the driver frame;
- drill pilot holes and temporarily screw the driver in place - it should now be "square" or "diagonal" depending on your preference;
- remove the driver and re-mount "backwards" on the front side of the baffle;
- using either double edged carpet tape or clamps, secure the template to the work piece and bench - it should self-register on the driver frame and bench;
- remove the driver;
- set depth of cut on your pattern following router bit;
- make sawdust , then have a beer
Last edited by chrisb; 2nd December 2009 at 08:22 PM. Reason: hopefully, clarification
fostex drivers babgrip Full Range 0 1st December 2008 05:13 AM
fostex drivers brian t Full Range 3 15th January 2005 05:08 AM
where can I get fostex drivers alg123 Full Range 4 26th August 2004 11:54 AM
Fostex Drivers Konnan101 Multi-Way 15 9th February 2004 02:15 AM
WTB: Fostex FE drivers MKChong Swap Meet 0 21st May 2003 03:55 AM
Page generated in 0.12391 seconds (82.55% PHP - 17.45% MySQL) with 11 queries
