At least I don't recall seeing these posted here. Here is the 6.5". That high Q resonance probably demands a notch filter, but that is a pretty speaker. It looks as if the idea of fullrange drivers is becoming more mainstream! Like many other newer entrants these are not high efficiency, but incorporate some fancy tech and relatively long excursion. They are an offshoot of modern domestic hi-fi woofers rather than designs more PA or vintage (which of course makes sense given the manufacturer). Of course, I'd rather you buy my speakers, but I believe that fullrangers gaining traction is good for all of us!
Paul Wild Burro Audio Labs - DIY Full Range Speakers |
#2 |
What hi Q resonance? The QTS is listed as .29 .
#3 |
I think the reference is to the sizable peak in the published curves. Vifa, by the way, specify response only to 4k, and the speaker is referred to as a "full range woofer" so maybe not quite a full-ranger as we generally think of them.
www.buyoutdickvitale.com: Pledge money to enable ESPN to get Dickie V off the air |
#4 | |
#5 |
The off axis response roll-off starting around 2K (quite steeply at 60deg - but then who does most of their listening with that much toe-in?) would also need to be taken into account when selecting mid/tweet driver & XO topology.
Other than that, rather nice looking graph up to 1K - of course the sound is the thing. This should probably be thought of as a wide-range woofer, could make for a simple 2-way with appropriate wide band mid tweet (pick your flavor)
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#6 |
Custom Title
That's a sexy driver, and that resonance, while harsh, isn't THAT bad, it's only 5dB and pretty high up.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#7 |
#8 |
Sure, they're snazzy, but how do they compare to other woofers you can get for $75?
#9 | |
#10 |
I would as well (the 2.5 especially). I am insterested in designing a TL or MLTL for this driver.
| So what does everyone feed their fullrangers with? | Rick J. B. | Full Range | 159 | 27th December 2009 06:36 AM |
| Tesla Fullrangers.... | JandG | Full Range | 9 | 31st July 2008 05:23 AM |
| 2 fullrangers > no crossover? | NurEinTier | Full Range | 8 | 28th December 2006 12:47 PM |
| What kind of amp for fullrangers? | wixy | Multi-Way | 7 | 27th December 2006 06:02 PM |
| diy fullrangers in oklahoma? | big_kahunah | Full Range | 3 | 23rd June 2006 09:06 PM |
| Page generated in 0.10862 seconds (77.32% PHP - 22.68% MySQL) with 10 queries |
