Minimalist
Fellas,
So I haven't done woodwork in months and am itching to hear some of the drivers that I have and never listened to. I was given a pair of AN Super 8 Cast Frame drivers and a pair of FE207e. I would like to build a single pair of enclosures that I can use for both drivers so I can have an apple to apple comparison. Any suggestions for enclosures? I was thinking an MLTL... Thanks, Josh |
#2 |
If the AN specs are even close i don't think you will find 1 enclosure that is even a good compromise for both.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 | |
Minimalist
My original plan was to try MJK's 206/207 Project, but my understanding is that that was originally designed for Lowthers, which have an even lower VAS than the Fostex.
I also thought about the Half Chang, but decided that may not be the best idea either. I did find an old post Scott made: Quote:
Dave, I'm sure you've got a suggestion for me. Josh |
#4 |
It's apples & oranges. They're two different drivers, with very different specs., which nominally at least means intended for different purposes (although the CSA site might suggest otherwise...
) A closer comparison would be the AN & FE206E; comparing to the 207 wouldn't tell you a whole lot that you couldn't already tell from a basic FR / impedance graph.
#5 |
These BIBs are close but not exact. Maybe a compromise between the two will work ‘well’ for both. Just a suggestion, build a BIB with a line of 176 (88” tall) x 10.5 x 14. It’s a little bit big for the Fostex and a little bit small for the AN… I think it will sound very good with either once stuffed. Or build the smaller Fostex BIB and use a circuit on the AN… it probably needs one anyway.
Godzilla http://www.zillaaudio.com/bigger_is_...iioNirvana.asp http://www.zillaaudio.com/bigger_is_...bib-fostex.asp Fostex FE207E L = (Line length) 174" Zdriver = Driver 35" down from sealed end of cabinet Sm = 133.875"^2 *Frequency response below is for this BIB Audio Nirvana Super 8 L = (Line length) 180" Zdriver = Driver 36" down from sealed end of cabinet Sm = 168"^2 Last edited by Godzilla; 19th November 2009 at 04:43 PM. Reason: bad urls |
#6 |
Minimalist
Godzilla,
I like that idea. When I was in class I started to draw everything and then realized that this was 7'-4"... too big for me. So I modelled the Fostex in Scottmoose's MLTL and it looks to perform pretty well. Josh |
#7 |
Are your drivers 'broken in'? I listened to my AN drivers for, uh well, like 4-5 months
#8 |
Minimalist
InclinedPlane,
I have heard neither driver. Both pairs were given to my by an audio dealer in Atlanta. He was trying to get into the whole fullrange idea... it never stuck. He had the 207s in a BR, similar the the 167 BR (with the port in the stand) and he heard about the Audio Nirvana drivers so he bought the Super 8 Cast Frame and tried those in the same enclosure (He sells, not builds). He is a friend of mine and was very generous and gave me all 4 drivers. Both sets of drivers have been broken in under his watch for many hundreds of hours, I'm sure the suspension has tightened up since it has likely been a while since they have had any play. Josh |
#9 |
Minimalist
I started work today, got 2 sheets of 3/4" BB. And made all the main cuts. Just need to cut the braces and start with the glue tomorrow.
I did find some very unfortunate news today... the 207 and super 8 have different mounting locations. While the driver cutout is within 1mm from one another, the mounting hole location is >.25". Tomorrow I'm gonna try and work on it and take some pictures. I'm very excited to hear these drivers, but i don't know what to do about comparing them. Does anyone have a good idea on how I can test each driver in the cabinet without making 2 sets of mounting holes. Is temporarily mounting a baffle acceptable? With the extra wood and the bit that I found in my shed, I may be able to make another enclosure for the 207 without buying any more wood. Josh |
#10 |
Either have 2 sub-baffles, or use a clamping mechanism that puts the mounting bolts outside the frame.
dave
| Enclosure for AN super 8 | ippo112 | Full Range | 34 | 27th June 2011 08:41 AM |
| FE207E vs. Klipsch Heresy (multi-ways) - A Ridiculous Comparison | rjbond3rd | Full Range | 11 | 1st March 2009 05:23 PM |
| Fostex FE207E bass reflex enclosure | Thomas B | Full Range | 9 | 29th January 2008 12:23 AM |
| Best enclosure for Audio Nirvana Super 8 | art_ok | Full Range | 2 | 28th June 2007 07:52 PM |
| Sub gurus, please tell me... (super-sub enclosure) | Fish Chris | Subwoofers | 24 | 24th January 2007 12:10 AM |
| Page generated in 0.12555 seconds (78.02% PHP - 21.98% MySQL) with 11 queries |
