Old 8th December 2009, 09:08 PM   #21
edjosh23's Avatar
So I'm about 90% done with construction and have them playing as we speak.
Now that my speakers have some sides on them they sound much better . But seriously, the rising response seems more tame now there there is some solid midbass. The low end could really use some help, and I have yet to put any serious series resistance. I'm going to start playing around with values soon. I only have listened to the AN8s thus far, I've yet to try the 207s and need to rebuild the suprabaffles for them (I want a different style than what I've done). Basically my suprabaffle will screw into the mounting holes that the AN8 uses. The FE207 will then mount to the suprabaffle.
I tried something different on theses, I decided to add diffusers. I cut a bunch of triangular strips and lined the back baffle with them. I then covered them with felt.
The overall sound: very wide soundstage. Lifelike. Detailed (likely due to the rising response). Male vocals really shine. Listened to a lot of Ray Lamontagne and Steely Dan. These are much more forward than the B&W 602s. Perhaps not as in your face as the FE127s (although it has been a while). So far have not had any listening fatigue, but at times I've gotten a little annoyed with how bright they can be.
Thanks,
Josh
Pic below:
Old 20th December 2009, 05:19 PM   #22
freddi is offline freddi  United States
freddi's Avatar
nice - wonder how AN-CF8 compare to W8-1772?
Old 21st December 2009, 05:46 AM   #23
edjosh23's Avatar
On Thursday Rahul (ra7) and I got together. I brought these, my FE127 in GM's MLTL and my Nuforce Icon. Rahul has a pair of AN8 in folded voigt pipes. We concluded that my ANS8CF in these enclosures were well balanced. These are lacking in bass, while his folded voigts served endless amounts of tight bass. My speakers also sounded more forward. When I get back to school in January I'm going to try out the FE-207 and see how it fares.
The w8-1772 looks like a great driver and definitely something I want to hear. I'm interesting in hearing more reviews.
Josh
Old 21st December 2009, 01:04 PM   #24
Hi edjosh23, beautiful work there.
1. Did you try BSC? I read the thread but haven't seen that mentioned (though you said you may try series resistance).
2. You mention that Raul's folded voigt had endless amounts of tight bass. Nice! Were they mass-loaded at the end, i.e. with a port or just open like a BiB?
Old 21st December 2009, 07:04 PM   #25
edjosh23's Avatar
Rahul's were not mass loaded, in fact the opening looked quite big, but Rahul tried different sizes and took measurements.
I have not tried BSC, I haven't ordered the parts yet. I did try some series resistance (only a 3.7ohm resistor) and didn't notice a difference.
Josh
Old 21st December 2009, 08:12 PM   #26
freddi's Avatar
hi edjosh23 - are your enclosures tuned by just a tiny slot? my Nirvana 10 input z curves with Woofer Tester 3 in ~41Hz tuned reflex and Karlson 15" cabinet (~50Hz) suggested effective fs on the 10 around 50Hz or higher - I think Vas might have been best measured in a sealed box
Old 22nd December 2009, 11:26 PM   #27
edjosh23's Avatar
The slot shown in the above photos was not completely cut out. The actual slot extends from side to side. I retained the original cross sectional area and length.
Josh
Enclosure for AN super 8 ippo112 Full Range 35 7th May 2012 04:07 AM
FE207E vs. Klipsch Heresy (multi-ways) - A Ridiculous Comparison rjbond3rd Full Range 11 1st March 2009 04:23 PM
Fostex FE207E bass reflex enclosure Thomas B Full Range 9 28th January 2008 11:23 PM
Best enclosure for Audio Nirvana Super 8 art_ok Full Range 2 28th June 2007 06:52 PM
Sub gurus, please tell me... (super-sub enclosure) Fish Chris Subwoofers 24 23rd January 2007 11:10 PM
Page generated in 0.09090 seconds (85.60% PHP - 14.40% MySQL) with 11 queries
