Sachiko Builld Thread
Old 20th November 2009, 11:40 AM   #41
mymindinside is offline mymindinside  India
will post results, was hoping to get them done today but couldn't get the tools in time. plan to do it tomorrow.
i think thats how much an entire sheet (8ftx4ft) of ply costs here
Old 23rd November 2009, 12:22 PM   #42
Finally managed to finish up my build today.
all glued up and set but no finish yet and so i didn't solder the drivers and the binding posts. wanted to listen to them though so just twisted the wire (single wire of cat6) around the driver and binding post terminals. terrible, i know, but i figured the sound would only improve once i had everything soldered together nicely. the amplification was whatever i could get my hands on, a cd/fm/tape player combo amplifier (again, it can only get better right?). speaker cable was 18ga. lamp wire (zip cord)
initial impressions were extremely positive, very clear and transparent. they image beautifully and disappear once you press play. i haven't damped the internal chamber yet, have some felt on hand but wanted to listen without it first. i did detect a little bit of shoutiness though,..a slight roughness in the upper mids. i think the solution to this is phase plugs...would lining the back chamber with felt help this?
what surprised me was that they handled rock and electronica without skipping a beat. what struck me was that the speakers were very rhythmic and had great timing. they sounded better as i moved further away, and i fear that i might lose out because my room will force me to be close-ish to them.
a big thanks to the designers..and to everyone for all the help... i think i might build another one for the living room!.
have put up some photos of the speakers as they looked today
cheers
mymindinside
Old 23rd November 2009, 03:06 PM   #43
Pit Hinder is offline Pit Hinder  Germany
Pit Hinder's Avatar
Send a message via ICQ to Pit Hinder
Congratulations! And don´t worry - the "shoutiness" will lessen when the drivers are broken in. This might take quite a few hours of enjoying music - what horrible fate.
Old 23rd November 2009, 05:36 PM   #44
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Electronics, cable, solder, and damping will all make for improvements, but they will still need some running in, 100 hrs gets you thru the worst of it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th November 2009, 04:57 PM   #45
doug20 is offline doug20  United States
Very nice build!
In a design like this what is the max SPL of the speaker?
Old 24th November 2009, 06:29 PM   #46
just a guy is offline just a guy  Canada
Originally Posted by doug20 View Post
Very nice build!
This is just a guess, but I'd think you would get about 96 db in 2 pi space within xmax. After that it would sound increasingly distorted but you could probably get at least 103 db (I don't know the xlim spec so it could be a lot more) before something breaks.
Old 24th November 2009, 07:20 PM   #47
frugal-phile(tm)
planet10's Avatar
Originally Posted by just a guy View Post
at least 103 db
At least. Fostex xMax specs seem to be quite conservation, and they are capable of much higher excursions before runnung out. I'd expect they can close in on 110 dB.
dave
Old 24th November 2009, 09:54 PM   #48
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
You'd need to go some to break Fostex units; suspension is progressive rate, so you'd likely fry the VC before sending the cones flying. Depends on listening distance, but in practice, figure on about 105dB 1m at Xmax, with plenty more if you're willing to accept a bit of compression (the 206 overloads fairly gracefully). Do yourself a favour though & don't try it on a regular basis. Over 85dB continuous causes hearing damage in the long term.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 25th November 2009, 04:51 AM   #49
quadtech is offline quadtech  India
Just saw the latest pics. Looking very nice. Congrats!
Old 25th November 2009, 03:04 PM   #50
Originally Posted by Scottmoose View Post
...about 105dB 1m at Xmax...
Ouch, my guess was way off. I guess I should be modelling and not guessing.
I think I should get off my lazy butt and build a pair already anyway. I've been talking about it for over a year and I've got drivers.
Sachiko Builld ThreadHide this!Advertise here!
Sachiko drvomir Full Range 14 26th August 2011 07:00 PM
Sachiko Build Thread! woodturner-fran Full Range 115 9th February 2010 10:11 PM
What to expect from Sachiko? GTR-33 Full Range 6 14th January 2010 06:51 PM
Sachiko's are done ! hifisucks Full Range 15 26th May 2009 07:55 AM
another Sachiko build ljk11 Full Range 17 26th January 2009 01:34 AM
