#21 |
Some translation may be required (assuming the
lingo is the same across India) - T-Nut - the local shop calls it a Tiger nut Threaded insert - they call it a D-type nut If you want 6mm ones, PM me and I'll mail them out to you. |
#22 |
haha
thanks quadtech that what i really needed. its tough for me to explain what i want because they know everything by some other name... will check at the shop today and if i don't find it will ask you to mail them to me. thanks again |
#23 |
i Managed to find only 6mm T threaded inserts ..will go with these i suppose.
quadtech, what did you use as a gasket between the driver and the front baffle? Last edited by mymindinside; 19th November 2009 at 12:19 PM. |
#24 |
My drivers were new in the box, and a adhesive-backed
closed cell foam gasket was included in the box. Check around with car audio guys if they sell speaker gasketing tape. Looks like this - Amazon.com: Speaker Gasketing Tape 1/8" x 1/2" x 50 ft. Roll: Electronics Worst case, you can probably make a gasket out of the white closed cell foam cloth which most electronic gadgets are packaged with (LCD monitor/TV, for ex). |
#25 |
frugal-phile(tm)
How wide was the sticky gasket -- or was it a strip?
Here i get FE167 and FE207 with really nice special made gaskets. FE166 & FE206 come with a thin strip of weather seal (draught exclusion tape). I always substitue a wider tape of the same sort. I use neoprene (black) closed cel faom tape used by the building indutry to seal the openings of doors & windows... here mostly to keep the heat in on cold days, but equally usful keeping the heat out in places where it gets hot. ![]() Homedepot.ca - Search - foam - Building Supplies,Indoor Living,Outdoor Living,Tools & Hardware,Value Centre,LePage,TAGO,TUNDRA,MONO,GE Silicone,Goop,Nailtite I note that Home Despot calls it foam tape... as per mymindinsides's earlier post, maybe we should start a wiki page with the various names that are used to describe the same thing, to make it easier for people to hunt things down. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#26 |
My drivers came with a really thin gasket, i think it was 3mm wide.
dont think that is good enough..will look around for something |
#27 |
frugal-phile(tm)
Yes that is the factory gasket. I still haven't found a good use for them.
dave
#28 |
Dave the idea of a wiki multi-name multi-regional dictionary for the same things would be great! and would become a reference for diyers worldwide
#29 |
going off to work on the speakers...
just wanted a word on the internal wiring. should i us cat5e or regular speaker cable... thanks guys EDIT: did some deep searching...think ill go with cat5 mymindinside Last edited by mymindinside; 20th November 2009 at 04:55 AM. |
#30 |
frugal-phile(tm)
| Sachiko | drvomir | Full Range | 14 | 26th August 2011 07:00 PM |
| Sachiko Build Thread! | woodturner-fran | Full Range | 115 | 9th February 2010 10:11 PM |
| What to expect from Sachiko? | GTR-33 | Full Range | 6 | 14th January 2010 06:51 PM |
| Sachiko's are done ! | hifisucks | Full Range | 15 | 26th May 2009 07:55 AM |
| another Sachiko build | ljk11 | Full Range | 17 | 26th January 2009 01:34 AM |
| Page generated in 0.10629 seconds (77.74% PHP - 22.26% MySQL) with 11 queries |
