#2 |
Not bad at all. The 5" variations look quite good. Is the paper doped because in the photo it does not look like it is. Ofcourse the stamped frame could be replaced or the phase plug could be better made but as a whole this is fantastic.
Obviously T/S specs and Freq. response and impendance charts would be needed and the driver's usability wqould be determined by how it sounds (break up nodes etc..).
...still looking for the holy grail. |
#3 |
Thanks Naveen.....
" Is the paper doped because in the photo it does not look like it is " No its not doped yet.... I do the doaping cum coating on the final version before I do acoustic measurments.....the coating enamel is very expensive.......... " Ofcourse the stamped frame could be replaced or the phase plug could be better " sure.... but the problem is the availability of cast frame for this size :-( but the stamped frame I have used for this 5" mid woofer is made out of 0.9mm steel, which is very very sturdy. " Obviously T/S specs and Freq. response and impendance charts would be needed and the driver's usability would be determined by how it sounds (break up nodes etc..). " would post all that info very soooon... atleast for the 5" mid woofer. thanks Sumit |
#4 |
Hi Sumit
Are you a manufacturer, or is this a DIY effort?
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#5 |
Hi Shaun
Its DIY effort..... but I do make a few drivers ( curently just woofers, sub woofers and mids ) only for diyers on order basis, if they like something that I have made.......... or if they have any similar requirements that I can fulfill...... its my hobby/passion.... and not a business. cheers Sumit |
#6 |
Hi Sumit,
The drivers look good. sent you a PM re: listening to them. i am in delhi for a bit cheers mymindinside |
#7 |
#8 |
Hi
U r right if proper mounting is not done one might get flex or sag..... need to support the magnet structure from within. The rear magnet can be removed if shielding is not needed. Had to use such a large motor to meet the required TS specs. cheers |
#9 |
Preliminary results of the 5 inch extended range driver (1" Kapton voice coil, full copper sleeve, coated paper cone, 5mm lin-Xmax p-p )........
1) The near field test was done from a distance of .5cm from the cone surface. more results to follow...... rgds Sumit |
| 8" mid/bass driver in chennai/india | js iyer | Multi-Way | 4 | 8th February 2010 11:44 AM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 07:42 PM |
| 12" "guitar" driver in Audio Speakers | jwhit67 | Multi-Way | 4 | 11th February 2008 03:47 PM |
| Peerless India: Anyone need 12" subwoofer driver? | yusuf | Parts | 0 | 10th January 2007 10:48 AM |
| Page generated in 0.12543 seconds (80.84% PHP - 19.16% MySQL) with 11 queries |
