Hello people.....
It seems people are getting into diying driver in India..... have been reading their posts.... very good that people are doing something for the diy community.....
Here I share a few images of my latest projects for all u wonderfull guys
1) 5" extended range driver
2) 5" mid woofer
3) 5" midrange
4) 8" woofer
5) 4" woofer
5" variations:-
http://i130.photobucket.com/albums/p266/sumitdutta77/5inanother.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/5inextendedrange.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/FullcopperTpole.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/Tpolemidwoofer.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/anothercompare.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/dampingunderspider.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/duringmachning.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/poleCopper.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/pole.jpg
8" woofer motor
http://i130.photobucket.com/albums/p266/sumitdutta77/DSCI0211.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/8inwooferrear.jpg
4" woofer:-
http://i130.photobucket.com/albums/p266/sumitdutta77/4inchwooferpole.jpg
http://i130.photobucket.com/albums/p266/sumitdutta77/4inchwoofer.jpg
Am working on a DIY dome tweeter currently... pictures & data soon enough...
enjoi
Sumit
2) 5" mid woofer
3) 5" midrange
4) 8" woofer
5) 4" woofer
5" variations:-
8" woofer motor
4" woofer:-
enjoi
Sumit
Not bad at all. The 5" variations look quite good. Is the paper doped because in the photo it does not look like it is. Ofcourse the stamped frame could be replaced or the phase plug could be better made but as a whole this is fantastic.
Obviously T/S specs and Freq. response and impendance charts would be needed and the driver's usability wqould be determined by how it sounds (break up nodes etc..).
Thanks Naveen.....
" Is the paper doped because in the photo it does not look like it is " No its not doped yet.... I do the doaping cum coating on the final version before I do acoustic measurments.....the coating enamel is very expensive..........
" Ofcourse the stamped frame could be replaced or the phase plug could be better " sure.... but the problem is the availability of cast frame for this
size :-( but the stamped frame I have used for this 5" mid woofer is made out of 0.9mm steel, which is very very sturdy.
" Obviously T/S specs and Freq. response and impendance charts would be needed and the driver's usability would be determined by how it sounds (break up nodes etc..). " would post all that info very soooon... atleast for the 5" mid woofer.
thanks
Sumit
thanks
Sumit
Hi Shaun
Its DIY effort..... but I do make a few drivers ( curently just woofers, sub woofers and mids ) only for diyers on order basis, if they like something that I have made.......... or if they have any similar requirements that I can fulfill...... its my hobby/passion.... and not a business.
cheers
Sumit
cheers
Sumit
preliminary measurment data....more to follow
Preliminary results of the 5 inch extended range driver (1" Kapton voice coil, full copper sleeve, coated paper cone, 5mm lin-Xmax p-p )........
1) The near field test was done from a distance of .5cm from the cone surface.
more results to follow......
rgds
Sumit
rgds
Sumit
- Full Range
- Some 8"/5"/4" driver DIY...... India
