Old 16th November 2009, 09:05 PM   #11
chrisb is offline chrisb  Canada
Originally Posted by Ty_Bower View Post
Has anyone here tried the Dayton binding posts at Parts Express? You just drill a 1/4" hole, and hammer the thing in. It seems pretty idiot-proof. It doesn't require much room to install, either.
Maybe OK for a car subwoofer with extra thick wall and testosterone involved, but how do you attach the wire to the ring terminal, and tighten the internal mounting nuts? Take a look at the room to reach the area in question on the Sachiko.
http://homepage.mac.com/tlinespeaker...v01-220309.pdf
this is one of the reasons I use cups in the first place - it takes longer to solder the 4 connections on the terminals and speaker than to drill the hole with a sharp saw - but then I'm just lazy that way
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 16th November 2009, 10:11 PM   #12
Ty_Bower's Avatar
Originally Posted by chrisb View Post
...how do you attach the wire to the ring terminal, and tighten the internal mounting nuts? Take a look at the room to reach the area in question on the Sachiko.
Ah, now I understand. So, whoever built the cabinets glued them shut without first installing any binding posts or wiring? Shame on him...
Old 16th November 2009, 10:14 PM   #13
doorman is offline doorman  Canada
doorman's Avatar
This is perhaps sacrilege, but the only Cardas binding posts I've personally used were the special patented ones, and I found them a total pain in the rear panel to install and use.
They do make a rectangular metal plate to simplify installation, as the Parts Express plates are nice as well, but the cheap round input cups and hole saw if you don't already own one can be purchased for less than the high zoot parts, and installation is a pretty quick.
If I was going to get any fancier than the cheap terminal cups, I'd probably go for the Eichmans
or WBT Next-Gens.
"2-3 dozen pairs a year", Chris-- those will put any anticipated retirement plans on-hold!
Don
Old 16th November 2009, 10:25 PM   #14
Ty_Bower's Avatar
Originally Posted by jleaman View Post
That's a'lot of metal for a small accomplishment, I think the idea here is less mass less metal and less forgin material.!
I'm not sure I understand the logic behind low mass binding posts. Are thick posts too hard to solder with a low-watt iron? Someone, please enlighten me...
Old 16th November 2009, 11:15 PM   #15
frugal-phile(tm)
planet10's Avatar
Low mass connectors (ie thinner metal) tend to sound better. Thatis why the best RCAs you can buy at radio shack are the plastic sleeved 8 for $5 (and in 4 different colours)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th November 2009, 12:50 AM   #16
or you could drill a hole in the back of the cabinet and thread your fav speaker wire, solder to speaker terminals and listen while you consider the many connector options available
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 17th November 2009, 02:17 PM   #17
Jim Shearer's Avatar
Here's what I have been using:
Parts-Express.com:*Gold Plated Banana 5-Way Speaker Terminal | SPEAKER TERMINALS speaker terminal speaker plate speaker gasket plates plate gauge gasket binding banana
I just drill two 0.5" holes for the wires to go through and attach the plate. Minimal disruption to the wood panel, minimal effort, low cost.
Cheers, Jim
A day without music is like a day without food.
Old 17th November 2009, 04:26 PM   #18
frugal-phile(tm)
planet10's Avatar
If you can live with the binding posts sticking out, those look good -- same 5-way posts as on the ones we use.
dave
Old 17th November 2009, 06:56 PM   #19
Cheers, Jim
dave
These appear to be exactly the posts found on current Hornshoppe Horns, and they're great. I guess it's really a matter of aesthetics as to whether you'll like to see them flush or proud.
Old 18th November 2009, 05:36 AM   #20
Default Ordered Parts Yesterday
Cheers, Jim
Ordered the Parts Express plates, but only silver were in stock. Then grabbed a set of Cardas binding posts made from billeted copper. Also bought 4 feet of Cardas SE 15 wire to use as the internal wire. Drivers are Fostex FE206E.
Guess we will see how this all turns out.
Mister Pig
3way XO help greatly appreciated! grantnsw Multi-Way 797 22nd October 2007 03:36 PM
Help greatly appreciated. timberman Chip Amps 2 6th March 2006 06:44 PM
Page generated in 0.11426 seconds (77.96% PHP - 22.04% MySQL) with 10 queries
