Old 16th November 2009, 09:34 PM   #11
Harderror's Avatar
Though it is not a bookshelf, my SPQR Model 2 fits the bill for what your requirements are. It is very efficient, hits 50 HZ uses a fairly inexpensive driver, and only takes up 14 x 14 inches of floor space. Really quite good.
Tom
Old 16th November 2009, 09:42 PM   #12
chrisb is offline chrisb  Canada
Tom
got a link or visualization?
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 16th November 2009, 10:05 PM   #13
Tom
I would actually prefer floor standers. Stands can get expensive and they are not terribly stable with my daughter running around (not to mention my German Shepherd and Golden Retriever!). I'll check these babies out further; I'm assuming the link in your sig is the best source for info?
Old 19th November 2009, 11:51 AM   #14
Harderror's Avatar
Well, I didnt' realize my link was no good anymore. Well, let me get that fixed and I will post another link.
Tom
Old 19th November 2009, 11:55 AM   #15
Harderror's Avatar
Ok, I let my domain name lapse as I have been really busy and had no time to take care of it. Here is s a link to the blog page that I keep this stuff on. The plans are a link on the right. S.P.Q.R. Acoustics
Tom
Old 19th November 2009, 04:31 PM   #16
mor2bz is offline mor2bz  United States
Default suggestion
av3 a sm. floorstander
i bet you take it out to the lounge though
also the ribbon version
DIY Kits
Old 19th November 2009, 08:38 PM   #17
Harderror's Avatar
Not really DIY if someone else does most the work for you no?
Tom
Old 19th November 2009, 08:48 PM   #18
Thanks for the suggestions so far. I checked out those kits and they do look interesting; I'm just a touch worried on the sensitivity. They look like they are only around 90dB and with only 8 ish watts to play with I was thinking I'd probably want something in the neighborhood of 93dB or better.
Tom, what kind of positioning flexibility is there with your speakers? Do they need corners? Can they perform well against a wall?
Old 19th November 2009, 08:53 PM   #19
picowallspeaker's Avatar
Why not hanging the speakers to the ceiling? I'm thinking of this solution , either.
I'd avoid the classic 6 faces-box ,moving toward a double prism design project. Then the driver's baffle would be a secant plane.The internal volume available would be much less due to the longitudinal structure...hmmm:the ceiling could help in some gaining like in some projects the woofer coupled to the floor does.
Bye ,,, I'll investigate.
Old 9th December 2009, 01:04 PM   #20
Harderror's Avatar
Sorry for the late reply. Yes, they function well on just a wall. I ran them like that in my old house. I have them in corners now and I have to say the difference in minimal. These speakers work well out in the room as well. Really quite amazing.
Technology Student Wanting To Build Full Range System morfius Full Range 46 12th September 2007 09:09 AM
Compact high power full range audio system (using gainclones). kuldeepsingh Chip Amps 5 29th September 2006 07:02 PM
Simple, Inexpensive, yet Decent Full Range/Single Driver system? dsavitsk Full Range 11 16th August 2006 10:40 PM
Looking for full range design jaybird Full Range 8 11th August 2004 10:58 PM
Page generated in 0.10819 seconds (77.09% PHP - 22.91% MySQL) with 10 queries
