#11 | |
build details here if you're interested Vitalstates- Amplifiers
There is nowhere you can be that isn't where you're meant to be www.vitalstates.org |
#12 |
Though Ed seems to have removed reference to his
Vofo from his main page, his design for the FE206E was well spoken of, here and other places - Vofo - hand made loudspeaker |
#13 |
Hi Quadtech,
i had looked at your sachiko build when you started the thread and was very impressed. Do you think i need to use marine ply? is the major advantage that it is void free? Also could you help me a little bit with the build process...this is my first build with this level of complexity so i need all the help i can get. cheers mymindinside |
#14 |
frugal-phile(tm)
The big benefits of ply is that it us stiffer & better damped. A much better material for this aplication. Also won't be affected by the monsoons nearly as much.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#15 |
Hi Dave,
Here in India, we get two kinds of ply. regular and marine plywood. Marine plywood is about 2x the price...i was planning on using regular plywood and was wondering if i needed to use the marine variety. Also, what did you use to seal the joints quadtech? Thanks mymindinside |
#16 |
frugal-phile(tm)
If one has more plys than the other use it.
dave
#17 |
nothing we get here has more than 6 plys (for 18m ply)...will just go ahead and use that i supopse....what are the tolerances for the cabinet dimensions?a few mm?or less?
thanks mymindinside |
#18 |
frugal-phile(tm)
Originally specified in inches i'd try to keep accuracy to a mm.
dave
| G Chang Questions | leeoh | Full Range | 16 | 1st January 2009 07:07 AM |
| Half Chang or Suzy Chang with Subwoofer? | tripathdude | Full Range | 2 | 15th December 2008 04:47 PM |
| OK straight AC bad how about this? 8000kva | ben62670 | Power Supplies | 12 | 6th February 2008 11:02 PM |
| Newbe questions TQWT using fostex FE206E | LazyJones | Full Range | 8 | 30th October 2007 03:27 PM |
| MLTL Design with Fostex FE206E Questions | JeffG | Multi-Way | 3 | 12th July 2004 06:06 PM |
| Page generated in 0.09894 seconds (74.45% PHP - 25.55% MySQL) with 10 queries |
