Old 2nd November 2011, 08:57 PM   #71
kevinr is offline kevinr  United States
just tried a 6 inch diameter port with 4 inch length. Blecch
Didn't care for what it did so went back to the stock 3/4 X 6 inch port.
I did notice that taking the grilles off improves the "tweeter" part of the cones performance slightly. Maybe getting the wooden grille edge out of the way helped.
I'm probably going to build a larger set of cabinets for these cast frame 12's at some point. My living room is too small for the 160 liter one , but the 80 l may be a bit too small for best performance.
I wonder if cutting rebates on the baffle to flush mount the drivers would be an improvement over their current surface mount ?
If I do build a larger cabinet I'll probably use at least 1 inch BB for the baffle and more window braces than the brace that the 80 liter cabinets that were built for me by Wyatt Woodworking. I'll do roundovers on the baffle edge too
Old 7th December 2011, 09:20 AM   #72
csjavik is offline csjavik  United States
Default Any idea on the Le rating for the Audio Nirvana drivers? I have the 12, 10, 8, 6.5's
I'm hoping someone will know the inductance rating on the Audio Nirvana drivers. Any ideas? I have thet 12, 10, 8, and 6.5's in cast, and the stamped basket 8's. Let me know if you know! Thanks!
Originally Posted by Michael Chua View Post
The Super 12 just came in for testing. Results of T/S are below. Measured with LMS, Delta Mass (20g added weight). Loaded in a 60L Sealed Box. Bass response is adequate for most music.
Mike
Old 7th December 2011, 04:06 PM   #73
GM is offline GM  United States
GM's Avatar
I don't have much faith in their published specs, but FWIW the sampling I looked at all have a calculated < 0.1 mH/20+ kHz inductance, so can be off a fair amount and still flat enough not to make an audible difference.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th January 2012, 05:44 AM   #74
dtossan is offline dtossan  Canada
Default AN Super 10
Hi roro1
Great to hear the EQ network works for you.
Once the mids and highs are tamed, the Super 12 sounds quite nice. It is not perfect but for the price and a bit of extra for the EQ components, it hard to beat. And it looks sexy too.
One aspect I like is the transparency which is very difficult to get in speakers with passive crossovers. I believe it is this transparency that attributes to its' "life-like" qualities. Enjoy.
Mike
Hi Mike
I learned so much from this. I'm thinking of using the AN Super 10 in a 2.8 cu ft cab due to room size. Do you suppose the 10" will be similarly peaky in response and need similar treatment.
Newbie in DYI speaker.
Dan
Audio Nirvana Super 15&quot; cast frame build mikeineugene Full Range 10 16th October 2011 04:36 PM
Fostex FE206E or audio nirvana super 8 cast? soundbadger Full Range 137 30th June 2011 08:04 PM
Audio Nirvana Super Cast 10" (New) ranger3 Full Range 268 27th April 2011 08:58 PM
audio nirvana super 8 cast frame in lowther 2.8 cabinet scbf81 Full Range 4 9th March 2010 11:20 PM
Cast frame Audio Nirvana 12 inch in open baffle jamikl Multi-Way 2 8th June 2009 11:10 AM
Page generated in 0.09673 seconds (73.27% PHP - 26.73% MySQL) with 11 queries
