Audio Nirvana Super 12 Cast Frame measured T/S - Page 2 - diyAudio
Old 14th November 2009, 12:20 AM   #11
MJK is offline MJK  United States
Originally Posted by FullRangeMan View Post
Do you think this Nirvana Super12CF is a good fullrange for a bass reflex no filter box??
I believe most full range drivers in almost any form of resonant enclosure, like a BR or TL or BVR, would benefit from the addition of a BSC filter (passive or active EQ). In my opinion, the only way to completely avoid a filter is with a really well done BLH enclosure design. There are not many BLH designs available that will produce enough SPL output below the baffle step to eliminate the need for some kind of filtering to rebalance the SPL response. Filtering can be the obvious inductor and resistor combination, a tube amp with a shaped response, or very exotic speaker cable. They all change the SPL output as a function of frequency.
Old 14th November 2009, 12:45 AM   #12
jamikl is offline jamikl  Australia
How would this speaker go as an upper bass - mid range on an open baffle? Martin, you seem to have an instinct for open baffles. Any thoughts on using one of these with perhaps the Fostex tweeter mentioned on the full range site linked to earlier in this thread.
jamikl
Old 14th November 2009, 12:46 AM   #13
FullRangeMan's Avatar
I think I afraid of the conseguences of this response. Thanks for clear.
Excuse my ignorance, but what are a BVR and BLH boxes?
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 14th November 2009, 01:08 AM   #14
Michael Chua's Avatar
When you are testing a driver to determine the complete set of T/S parameters, you need to make two impedance curves.
Hi Martin
Thank you for taking the time for a detailed explanation.
Gustavo
You can see from the Free Air Impedance Sweep that Fs is 35Hz. The green plot is when 20g weight is added to the cone. Fs now is lower at 25Hz. With these readings, LMS calculates the T/S.
This is the first step because I don't depend on manufacturers' T/S. Some can be grossly different. Once with the actual T/S, it is easy to model the type of loading.
Based on a 150L box, a Sealed Box F3=65Hz. When loaded in Vented Box (Bass Reflex), F3= 57Hz. If you want lower, you can go down to F3=37Hz with a 329L Vented Box. That's a very big box for home use.
Personally, I wouldn't load the Super12 in a BR. According to their specs, Xmax = 1.0mm. Much safer in a Closed Box.
ampslab.com/blog
Old 14th November 2009, 01:18 AM   #15
Originally Posted by Michael Chua View Post
Hi Martin
Gustavo
I could prefer a sealed box, it is more easy to tuning than a BR. What do you think about a 419 litres sealed box for three Super12CF?
Old 14th November 2009, 01:28 AM   #16
BLH = Back Loaded Horn. This is typically defined when the back of the driver's cone is firing into a small coupling chamber connected to a long expanding folded horn-like enclosure. The air in the long horn-like path exhibits standing waves at low frequencies similar to a TL.
BVR = Big Vent Reflex. This is typically defined when the back of the driver's cone is firing into a modest size coupling volume connected to a shorter expanding port that sort of looks like a short horn. A bass reflex typically has a larger volume box with a smaller cylindrical port. In a BVR the low frequency response is more bass reflex then horn, the coupling volume is a small stiff constant pressure spring and the expanding vent is an abnormally large moving mass, the two combine to produce the same low tuning frequency as a traditional bass reflex design. The physics of a bass reflex and a BVR are the same but the proportions are different.
Old 14th November 2009, 01:40 AM   #17
jamikl,
I think an OB design might be tough. I see two options, neither of which I have done any more work/thinking beyond typing this response. The problem is that the AN driver is 97+ dB/W/m efficient.
1. Run the AN full range and then try to blend a helper woofer to reinforce the bass lost due to the open baffle roll-off. The woofer or woofers would need to be efficient to prop up the loss of bass due to the baffle The down side is that the AN driver is forced to run full range and produce bass, but it is somewhat limited by the low Xmax value.
2. Cross the AN over to woofers around 200 Hz as I have done in the past on my OB designs. The down side here is that you will need woofer output that is 5 to 10 dB above the 97 dB/W/m of the AN driver. This would require multiple efficient woofers and/or an active crossover with plenty of boost capability.
I guess an OB design could be done if you are careful and select the right woofers and crossover plan. Being aware of the options and managing the design trade-offs is going to be the key.
Old 14th November 2009, 01:42 AM   #18
Thanks Mr.Martin for this clear explanation, I can say I never see a such BVR enclosure, seems very interesting.
For now I have idea to put three Super12CF drivers in a around 420 litres traditional bass reflex box, if it have a good full range sound, what I have to see yet.
Gustavo
Old 14th November 2009, 01:23 PM   #19
Below are the FR sweeps done at 0.5M_1W. Top plot is a 300 point precision Gated sweep from 1K-20K. Lower plot is without gating from 200Hz, smoothed 1/6 dB.
This confirms my initial listening test. The highs are definitely not well integrated. Quite shocking to see a response like that.
Looks like the tweeter starts at about 1K5 and ends at 7K5. Beyond that, its cone breakup.
Frankly, in its present state, its quite unbearable to listen to. Sounds like a raw extended range PA 12".
I'll see what can be done to minimize these irregularities passively.
ampslab.com/blog
Old 14th November 2009, 01:36 PM   #20
Scottmoose's Avatar
Cheers for posting all this Michael. Out of interest, if you've taken one, could you post an impedance plot (useful for showing breakup modes etc).
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Audio Nirvana Super Cast 10" (New) ranger3 Full Range 310 5th June 2014 04:45 PM
Audio Nirvana Super 15" cast frame build mikeineugene Full Range 10 16th October 2011 05:36 PM
Fostex FE206E or audio nirvana super 8 cast? soundbadger Full Range 137 30th June 2011 09:04 PM
audio nirvana super 8 cast frame in lowther 2.8 cabinet scbf81 Full Range 4 10th March 2010 12:20 AM
Cast frame Audio Nirvana 12 inch in open baffle jamikl Multi-Way 2 8th June 2009 12:10 PM
Copyright 1999-2017 diyAudio
