Neodymium magnets vs Ferrite magnets
Old 12th November 2009, 03:09 AM   #21
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by thoriated View Post
The ferrite drivers that replaced alnico versions were generally heavier due to the greater magnet mass required to give the same gap flux.
Quite true. Thanks for mentioning that. The Alnico magnets were mostly rod shaped. I.E. the magnet is the pole piece. So magnet geometry is different.
Don't know how the neo magnets are done.
Anyone?
Take the Speaker Voltage Test!
Old 12th November 2009, 03:10 AM   #22
blueae1405 is offline blueae1405  United States
blueae1405's Avatar
So it's all about looks when higher end speakers use Neo magnets? There is really nothin better that Neo has then Ferrite?
Do Neo magnets last longer and are they usualy durable? Since if that's the case maybe that's the biggest reason why they use Neo on higher end speakers.
Old 12th November 2009, 03:31 AM   #23
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Hmm, you get higher magnet power on alnicos by increasing the length
On ceramics its the opposite, its more effective to increase diameter
Greater thickness gives less
Optimal size of ceramic magnet could easily end up being as big as driver mounting hole, or bigger, which isnt practical
In the old days with alnicos it sort of worked on its own
When forced to use ceramic instead problems began
Concerns flux variations caused by the moving voice coil
Oh, I actually forgot the only thing I wanted to say
One reason some use high power neos is because it really is the only way to get close to alnicos, and its cheaper
Old 12th November 2009, 03:52 AM   #24
thunk303 is offline thunk303  Australia
thunk303's Avatar
Neo is often the only choice when building something like a tweeter where a compact body allows placement much closer to the mid range driver.
Is that foam between the neo magnets on the Tangband?
Old 12th November 2009, 04:26 AM   #25
ted4412wilt is offline ted4412wilt  United States
I think the small size of Neo magnets gives less restriction to the backside air flow. The lowest distortion midwoofer I have ever seen used Neo.
Ted
Old 12th November 2009, 04:39 AM   #26
Iain McNeill is offline Iain McNeill  United Kingdom
diyAudio Moderator Emeritus
Iain McNeill's Avatar
The target application is important too. Is this a high power, high reliability application (e.g. 18" driver 200' up in a stadium scoreboard) or is it a portable music player (minimum weight, maximum efficiency)? Different strokes, YMMV, etcetc.
As I said, there's no best, just least bad - and its different for everyone.
Old 12th November 2009, 04:43 AM   #27
mp9 is offline mp9  United States
a shielding cup is a mickey mouse way of doing it unless it's also enclosing a bucking magnet. they do helps in other ways too, think spendor.
Old 12th November 2009, 04:44 AM   #28
Does anyone have any data on the 'resilience' of the different magnets. What I mean is, when you put a big signal through the voicecoil it generates a significant magnetic field of it's own. How does neo respond to that counter field with respect to flux saturation in the core and dynamic range compared to ferrite & alnico?
Old 12th November 2009, 05:00 AM   #29
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Barkhausen noise in drivers and inductors
http://www.diyaudio.com/forums/multi...ainstream.html
http://www.diyaudio.com/forums/multi...ng-magnet.html
http://www.diyaudio.com/forums/full-...ke-alnico.html
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th November 2009, 05:09 AM   #30
..without leaving the site
Thanks Dave!
Neodymium magnets vs Ferrite magnetsHide this!Advertise here!
Neodymium magnets NickC Full Range 1 19th May 2008 10:41 PM
Neodymium magnets Geoff H Planars & Exotics 0 18th June 2007 01:59 PM
Neodymium Magnets Frazzled Everything Else 4 25th July 2004 06:42 PM
Neodymium Magnets sdman Multi-Way 7 7th January 2002 07:34 PM
