Last night I started building a set of Micro Fonkens out of some 3/4" solid pine that I had sitting around, an old shelf in my garage actually that had a split at one end.
3/4" makes the design a bit fatter looking than normal. I've altered some of the dimensions slightly so as to keep the internal volume and port volume as close to the original as possible. The biggest potential problem though is that I don't have any FF85K ![]() For now I'll be using some H/K drivers out of my computer speakers. At the least it will give me something better looking to sit on my desk at work, and it just might sound better than the plastic cabs. Here are the (horrible cell phone) pics of what I have so far. ![]() The plans taped up on the wall for easy viewing. ![]() I clamped a board on the side of the radial arm saw so that it was easy to get all the side, front, and back pieces the same height. ![]() This was the first time I had ever tried to cut a circle with my router. I made a jig that the motorboard rotated around that allowed me to get some nice neat circles cut out. ![]() Some of the pieces sitting around. ![]() Part of the first one getting glued and clamped. Peace, Josh
...sword and pistol by his side. |
#2 |
Cool, keep those pictures coming.. I tell myself once in a while that I really ought to be making some decent computer speakers to replace the cambridge soundworks 3 piece system I currently have..
www.kta-hifi.net |
#3 |
I think I have those same Cambridge soundworks speakers. I built a set of these a few months ago and they get heavy use connected to our bedroom TV. Occasionally I bring them into my office when I'm working from home. I like them so much I am building a second set as a wedding gift for a friend.
#4 |
That's what I've been thinking about.
My brother in law is getting married next july and I was thinking about building a set(with proper wood and drivers) and maybe a small sub and a chip amp. -Josh
#5 | |
How are you going to work the holey brace so that you can swap to the proper drivers in the future. Installing the HK, into a box for the FF85 is a bit of a crap=shhot, hopefully they turn out tolerable dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 | ||
Than when it comes time for the FF85 if the brace is too large I'll carve it back a bit with a 1/2" router bit, if it's not large enough I'll build it up with another strip of pine glued on. Quote:
About the chamfer, would it hurt drastically to round the edges of the chamfer a little bit or should they stay fairly sharp? Thanks, Josh
#7 |
smoothing the edges of the champher would not hurt. Our builds are sharp to make them easier to veneer.
dave
#8 |
Update with some more crummy pictures.
More clamping and glueing, ![]() The work shop, a big step up over my previous setup which was a borrowed table saw in my driveway. So far my most expensive tool is the Bosch Jigsaw for which I paid $89 USD. I love craigslist. ![]() A preliminary test without the top and bottom glued on. And my new Lenovo T500 ![]() Left, ![]() Right, ![]() Still to come, Cutting the front chamfer, Mucho sanding, finishing. I'm probably going to use a cherry poly finish on them. Oh yeah, They sounded pretty good. Fairly weak in the lower frequencies. Not really expecting much there. They imaged much better than expected, probably in part to having them hooked up to a "real" amplifier. I can't imaging the stock unit built in as being that great. So, anybody recommend a chip amp to build? I'm decent enough with a soldering iron although I'm not that up on electronics but I can follow directions Peace, Josh
| uFonken flat-paks | planet10 | Planet 10 hifi | 15 | 11th May 2011 08:51 AM |
| uFonken speaker cabinet: Design question | underwurlde | Full Range | 30 | 14th October 2009 05:11 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 08:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 10:52 AM |
| X-Over... Can I Pay someone to build a X-Over. | Intelonetwo | Multi-Way | 0 | 13th August 2003 02:22 AM |
| Page generated in 1.18508 seconds (9.60% PHP - 90.40% MySQL) with 10 queries |
