Old 6th November 2009, 11:55 AM   #1
Colin is offline Colin  United Kingdom
Default Jordan MLTL port exit query
I'm planning to build a triangular version of the 31" JX92S MLTL by GM and would appreciate some input on how the port exits.
The port will exit from the floor of the MLTL, extending the tube below the bottom of the cabinet. So effectively it's enclosed by a cavity. The query is regarding a stand - I would like to make this by simply extending the enclosure walls downwards and 'venting' the whole area via three large holes.
Attached diagram probably makes this clearer.
In doing this, am I likely to cause this area to act like an additional resonant cavity with three ports? (I don't need to further load the MLTL's port as I'm going for an accurate roll off rather than any emphasis in the bass.)
Old 6th November 2009, 04:58 PM   #2
chrisb is offline chrisb  Canada
OK, Colin, this is a stupid question - but if the stands are permanent, why not just build the taller design?
Of course you could do something like this, per Jordan's UK site:
Your sketch suggests a triangular version, which would only slightly complicate the cutting of the deflector.
I made a pair of the 48" triangular enclosures a couple of years ago, and they certainly work.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 6th November 2009, 06:02 PM   #3
The 'stands' are really just an extension of the enclosure wall, extended five or six inches to get the driver up to height and allow the port to clear the floor. The problem is then getting the sound out from inside the stand! I could forget extending the sides and simply build in legs but I prefer the look of this.
Opening up one side with a reflector is possible, albeit increasing the tricky angles to cut. Plus I was hoping not to load the port, I'm going to integrate with a sub so I'd prefer no emphasis in the bass.
Yes, I've built the 48" triangles and they work fine. Time to try the more accurate 31" version but, unlike the 48, the port isn't short enough to fit horizontally.
Old 6th November 2009, 06:26 PM   #4
How about a simple tripod table - i.e. a solid 32mm^2 post in each corner, with a hole for the down firing port?
or an elbow in horizontal port
Old 6th November 2009, 06:34 PM   #5
Well, the tripod is what I'm trying to avoid. And I'd like to keep the purity of the port exiting straight down, no obstructions. Thanks for the ideas though. I'll go with the tripod if the original idea doesn't work.
I was going to build the rectangular cabinet you posted earlier but the Household Authorities are rather fond of the triangles and have been campaigning for their return.
Old 6th November 2009, 09:18 PM   #6
planet10's Avatar
As long as the holes are sufficienty large you should have no problem. If they triangualr enclosures are pushed back against the wall, you will onlty have 2 holes.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th November 2009, 10:02 PM   #7
Thanks, for that. They'll be 6"+ diameter. Glad to hear I'm not inadvertently creating more reflex ports!
Jordan with a Ribbon MLTL Jim Griffin Full Range 196 3rd February 2011 11:55 AM
jordan mltl 48 Smokeyone Full Range 161 10th December 2008 04:50 PM
Jordan MLTL port question Ivan Petrov Full Range 14 18th June 2008 06:42 PM
Effects of non standard boundary loading a port exit? ShinOBIWAN Subwoofers 4 30th July 2006 07:31 PM
Page generated in 0.12932 seconds (77.14% PHP - 22.86% MySQL) with 11 queries
