Initial Impressions: Alpair 12 full-range driver by Mark Fenlon
Old 28th March 2010, 07:37 PM   #71
creekkumar is offline creekkumar  United States
Jozua,
I do not have tube amplifier so no comment on comparison. With SS, the sound is very clean (should use quality amp) and the bass is very tight and clean. If you hear first time, you might feel there is no bass due to absence of boom type bass. But after couple of days you start appreciating clear bass.
After living with these speakers and these speakers being very smooth, I wanted more. I always prefer sparkles in top end. Alpair being very smooth, I decided to add a tweeter. Bought few and tried different combinations. Finally, I decided to keep Alpair with Tang Band 25-1744 ceramic tweeter crossing at first order with 5 - 6 uF capacitor.
Parts-Express.com:Tang Band 25-1744S 1" Ceramic Dome Tweeter | Tang Band 25-1744S tang band tb speakers dome tweeter ceramic dome hard dome non-metallic dome
Let me warn you that this tweeter is very good but if you do not have quality components it may sound harsh. Very thin line between detailed and harsh. In my case it is very detailed. For example if song has orchestra playing violin in background without the tweeter you will hear violin with veil but with this tweeter everything in background come alive.
This change is like you have Alpair as smoothie with cream on it. Adding TB tweeter is like putting cherry on top of it. I like cherry, others may not like it.
But I also like to emphasize that if you like cherry do not go with soft dome tweeter. Tweeter has to be hard dome and you can not go wrong with TB ceramic tweeter.
Have fun experimenting.
Creek
Old 16th June 2010, 06:25 PM   #72
Strunki is offline Strunki
Originally Posted by creekkumar View Post
Jozua,
Creek
Hello creek,
very interesting. What is about the spatiality ?
I am planing to combine the A12 (horn loaded) with an plasma tweeter.
Cut off frequency around 6 kHz (both drivers, FIR with latency compensation, numbers of taps has to be checked).
But i am a little bit afraid of an decrease in spatiality, because of going to a 2-way system.
I am asking, because your tweeter should be near to my cut off frequency.
After the arrival of my A12, i will open a separate post with my plasma projekt.
best regards from germany,
Markus
Old 17th June 2010, 04:12 AM   #73
markaudio is offline markaudio  Hong Kong
markaudio's Avatar
Originally Posted by Strunki View Post
Hello creek,
Markus
Hi Markus,
Could I suggest you talk to Blue Planet Acoustic in Frankfurt. They have my No.6 tweeter. This is a near-flat response unit running to 30-kHz. It may be worth considering this tweeter the Alpair 12, making a network crossing above 12-kHz. The middle to upper middle output range on the Alpair 12 is strong. Crossing at 6-kHz means losing some of the best performance range from the Alpair 12.
Mark.
Old 18th June 2010, 09:24 AM   #74
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
another option is to mount the tweeter up or slightly rear firing (often referred to as ambient tweeter), and just a cap on the tweeter (and maybe some attenuation), no x-over on the full-range. this does add te sought after "sparkle" to the highs, without loosing any of the full-range benefits
Old 18th June 2010, 10:52 AM   #75
markaudio's Avatar
Hi Henkjan,
Sounds like a very interesting idea. I'll do some experimenting.
Hi Markus,
I forgot to mention the Alpair 12's on-off axis character. On axis, its high range delivery is strong so you may want to experiment with the positioning of the speakers before making the crossover. You may find you like the high range with almost no assistance from the tweeter.
You can see an independent test from Japan of the Alpair 12's performance including off axis measurements:
Japanese Alpair 12 Review Now Available | Markaudio
Cheers
Mark.
Old 18th June 2010, 11:28 PM   #76
norman bates is offline norman bates  United States
norman bates's Avatar
Seems most full ranges benefit from a rising response then the listener sits a bit off axis.
I beleieve most recommend crossing the axis in front of you.
perhaps a notch at 7khz would help..................
Norman
Old 19th June 2010, 12:14 AM   #77
oops nevermind the notch comment in post #76
I applaud the high end response without the use of a whizzer.
I'm glad I've seen this.
I may make a call on monday and order the 12.
Thanks.
Norman
Old 19th June 2010, 02:20 AM   #78
italynstylion is offline italynstylion  United States
italynstylion's Avatar
Thanks.
Norman
We have both colors in stock at Stereo Clarity.
www.StereoClarity.com
Old 19th June 2010, 03:16 AM   #79
trusound is offline trusound  United States
trusound's Avatar
Send a message via AIM to trusound
I'll have to try these completely naked one day
Randy Kunin
www.randall-k.com
Old 19th June 2010, 04:11 AM   #80
italynstylion, nice site. I was flipping through your setup of drivers last night. Can I send stereoclarity a money order instead of a credit card ?
Norman
plz send email, I'll check it monday
jabates@rockwellcollins.com
Initial Impressions: Alpair 12 full-range driver by Mark FenlonHide this!Advertise here!
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 75 23rd May 2018 06:36 PM
F2 Initial Listening Impressions Biosonar Pass Labs 203 23rd January 2012 02:19 AM
Alpair 12: Initial Impressions drspence Full Range 1 5th November 2009 07:07 PM
CSS FR125S Initial impressions Timn8ter Full Range 15 18th June 2005 05:20 PM
