#61 |
here are pics.....
#62 |
Bravo Creek. Job well done!
www.StereoClarity.com |
#63 |
Hi Creekkumar,
Excellent work - well done! Wish I could take time out to listen to your system. Here's a possible suggestions for you. It may help to improve the flow coming from the back of the driver's cone if you open up the mount a little more. The Alpair 12's cone is very sensitive, best try to minimise any wood edge profile that might reflect part of the cone's pressure wave back towards it. I've Photoshoped your pic to help illustrate my suggestion. Hope this helps Cheers Mark. Markaudio |
#64 |
Thanks Mark for you suggestion. The inside circle diameter is 5.75 inches which is outer diameter of suspension where curvature stops and is glued to the frame. The wood thickness is 10 mm after trimming for driver. My only intension was to provide enough mechanical strength to wood by providing enough width and as the internal edge ends before suspension starts theoretically it should not hinder air flow. But I could be wrong, pls let me know where the edge should be in inches to not to effect air movement.
Another request is if you can share waterfall and THD measurement with us that would be great(like zaphaudio.com have) I am sure it would be way better than other drivers but this information would help all potential full range buyers in making buying decision easier. I am assuming you have seen ads of AT&T and Verizon on TV about them trying to convince how one is better than the other. I believe quality product with right tools and marketing strategy provides guaranteed & sustainable success. Above tool can be one of them. Thanks & Regards Creek |
#65 |
Hi Creekkumer,
Please take a look at the attached pic. You may have a recess profile similar to this illustration? Ideally, its best to have a radius facing out and away from the cone. Depending on the wood thickness but something around R=5-mm is nice. It may be useful to consider opening the cut-out to 6.65 inches (169-mm). This would make the hole size just shy of the legs on the Alpair's frame (as per my earlier pic). But if the music reproduction is clean and clear under load, then its OK to stay as is. I'm hoping to purchase a whole new measuring system this year. I had hoped to do it last year but the economic slide put pay to that. Last time I looked at Zaph's site, a cheap Berringer mic was in use. Not wishing to disappoint folks but it takes a pile of money going into anechoic chambers, hardware, software and mics to get the job done properly. Data generated from lesser systems shouldn't automatically assumed to be totally reliable and accurate. For now, I've got access time to a purpose built anechoic chamber, LMS, signal measuring + my own bespoke equipment that deals with cone and power-train development. In the meantime, there's a good number of folks on this forum and in Germany and Japan who will vouch for the accuracy of the existing data that I provide. Being an Mech Eng. by nature and training, I'm guessing you'll know from which direction I'm coming just by owning and using a pair Alp12's. I hope you get many hours of pleasure from them. I'm not saying my drivers are the best in the world, but am I'm trying my best to build in more performance and value for money. Cheers Mark. |
#66 | |
Late to the party....
#67 | |
#68 | |
no doubt designers of drivers and speaker enclosures relish all this second guessing
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#69 |
Especially when the Alpair flanges are some the best designed I have worked with (at least in building with the 7 and the 12).
#70 |
Creekkumar
How does the speakers sound with your transistor amplification ? I have a friend with Fostex FR drivers in 7 foot boxes which are very listenable with a very good soundstage but lacking in ultimate detail and bottom end tightness which I have in my system but I do not have his consistent soundstage. Feedback will be appreciated. Jozua Regards Jozua |
| F2 Initial Listening Impressions | Biosonar | Pass Labs | 203 | 23rd January 2012 02:19 AM |
| Alpair 12: Initial Impressions | drspence | Markaudio | 1 | 5th November 2009 07:07 PM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
| CSS FR125S Initial impressions | Timn8ter | Full Range | 15 | 18th June 2005 05:20 PM |
| Page generated in 0.12196 seconds (81.04% PHP - 18.96% MySQL) with 11 queries |
