Old 31st October 2009, 02:15 AM   #1
Question Finished FE126e BLH Enclosure. Damping required?
After a hilariously long construction period, I finished my back-loaded horn reference design enclosures for the FE126e. I'm finally getting around to gluing them, but before I do, I wanted to double-check that I don't need to put any padding or damping material in the enclosure?
I've never seen it referenced in any build logs of these enclosures, and it's not mentioned on the foxtex-provided plans.
btw, they sound fine to me right now, so unless it's going to make a noticable difference I won't bother...
Old 31st October 2009, 03:30 AM   #2
Ty_Bower's Avatar
The "Fostex Recommended" design that I've seen is a bass reflex / back-loaded horn hybrid. Is that the one you built, or are there some other drawings out there?
Old 31st October 2009, 05:05 AM   #3
Yep that's the one - sorry, probably should have linked it
Old 31st October 2009, 05:18 AM   #4
planet10's Avatar
You will probably need to line the bass reflex box. We were never very thrilled with our build of this box.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st October 2009, 08:52 AM   #5
dave
Do you mean the lower section of the BLH+BR hybrid enclosure, or are you just referring to the regular BR type enclosure? What didn't you like about it?
Old 31st October 2009, 09:08 AM   #6
planet10's Avatar
It really doesn't have any real horn in it... the labirynth is really an expanding Big Vent -- long enuff that it starts acting like a TL. The other port just makes performance less predictable.
You need to damp the BR chamber just like you would a regular BR.
All the time we listened to these we speculated about what could be done to improve the quality of the bass... and they didn't seem to go that low. Once we got to the point of (in our heads) adding a woofer, we realized that a much simplier sealed, or aperiodic loading of the FE126 would be better idf we pursued it.
It did inpire us to build a set of folded monopole diyA ref ML-TLs for the FE127... their performance was much better.
So in the end we relegated the FE126 hybrid thingies to the scrap heap along with the Fostex recommended horn for the FE103. Good, but less than steller performance of the Fostex recommended horn for the FE206eSR has us a bit gun shy about Fostex's designs. We did hear the recommended horns for the FE166eSR, and quite enjoyed them, but couldn't help speculating how they would sound in a properly adjuste Austin A166 or Spawn Hiro.
I hope you have better luck with yours.
dave
Old 31st October 2009, 09:49 AM   #7
planet10's Avatar
Here is a picture... finished ones are the diyA FR ref ML-TLs
dave
Old 31st October 2009, 12:23 PM   #8
Thanks for all the info dave. Honestly, when I first had a listen to them I was disappointed in the lack of bass.
After living with them for a few months, however, I've started to appreciate the clarity in the high end. If I ever get round to it I'll try pairing them with a small sub.
Still, I'm pretty happy with the way they turned out considering they were my first build.
I'll have a play around with some stuffing tomorrow.
How to get optimal enclosure damping? cirrus18 Multi-Way 5 7th April 2009 04:45 PM
FE126E + SF Wool Cone Finally Finished! musgofasa Full Range 9 5th December 2008 06:28 PM
fe126e 2 way enclosure with woofer lionking7 Full Range 21 26th July 2008 04:25 AM
FE126E in a 23 litre enclosure audiophile36 Full Range 14 23rd September 2006 11:49 AM
FE126E enclosure question Skitch72 Full Range 4 18th March 2005 05:55 PM
Page generated in 0.10298 seconds (77.02% PHP - 22.98% MySQL) with 11 queries
