Old 30th October 2009, 04:29 PM   #11
Scottmoose's Avatar
Then assuming the claimed specs are accurate (I have some reservations) CSA's 13.6 box should do a decent job if tuned to 31Hz.
Old 30th October 2009, 04:38 PM   #12
yan6 is offline yan6  Canada
In what respect do you feel the specs may be inaccurate. Maybe a noobe question here, but tuning to 31Hz is done with the port size?
Old 30th October 2009, 05:26 PM   #13
Scottmoose's Avatar
Yes to the latter. For the former, the AN drivers, irrespective of their sonic merits (or otherwise) often seem when tested by owners to have a substantially higher Q than claimed. That could be one of any number of things; they could be over-stating the specs., manufacturing tolerances might be quite wide, or the home-measuring gear might have different operating criteria, as has been found elsewhere. Make of that what you will.
Old 30th October 2009, 05:54 PM   #14
As for the cabinet, can the dimension be changed while retaining the 13.6 cubic feet. I think I would be interested in making them taller and less wide and moving the driver up to around 40" from the floor. If this is possible how does one determine the height of the port to the speaker and the size and length required.
Thanks for the help so far
Old 30th October 2009, 07:23 PM   #15
Scottmoose's Avatar
AN 12CF MLTL. 58in x 16.5in x 24.5in (internal HxWxD). Zd 18in (sub optimal, but puts it at 40in + thickness of cabinet base off the ground). Vent 7in diameter x 0.75in long 3.5in up from internal base. Line top, back & one side-wall with 1in acoustic fiberglass & adjust vent length & damping quantity to taste from there. This is bordering on a pro-audio style alignment. Should do OK.
Old 30th October 2009, 07:29 PM   #16
frugal-phile(tm)
planet10's Avatar
The metronome for the cast frame is smaller. 6x6 to 20x20,
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th October 2009, 08:29 PM   #17
Scottmoose's Avatar
Variety = spice of life. Or something. The MLTL has more gain if required; ~equivalent Metronome would be to increase Sl to 25in x 25in with a 5in diameter x 0.75in long vent; length, St & Zd as existing box.
Audio Nirvana super 8 nirvana Full Range 10 19th July 2010 10:07 AM
Audio Nirvana Speakers Retrosonic Full Range 1 23rd December 2008 04:43 AM
Audio Nirvana autheim Multi-Way 6 21st November 2006 11:46 PM
Audio Nirvana - Where Is It? How Do We Get There? Bas Horneman Everything Else 9 25th January 2006 02:05 AM
Page generated in 0.09662 seconds (76.15% PHP - 23.85% MySQL) with 11 queries
